I've been using this method (Running off a live CD on both ends, and in root shell, as suggested in another of my questions) to clone one computer I've got set up to my liking to four others with the same hardware.
The first two clonings went smoothly, but when I try the
sudo dd if=/dev/sda of=/dev/stdout | nc 1.2.3.4 5678
(with the correct ip, of course) on the third computer to clone, after a short delay I'm greeted with the root@ubuntu:~# prompt again, rather than having to wait ~3 hours as it actually does the cloning.
When I Ctrl+C out of the nc on the receiving end, here's what I see:
0+0 records in
0+0 records out
0 bytes (0 B) copied, 1.6317 s, 0.0kB/s
dd: closing input file '/dev/stdin': bad file descriptor
The other clonings went fine, and all the computers I'm cloning to should be identical other than in name/ip address etc (Although I'm only human, and may have set them up slightly differently by accident, hence why I'm cloning to ensure they're all the same in the end).
Any idea why this one particular computer refuses to be cloned to (Or why the sender refuses to clone to it?)
