I also had to define the GNOME22_USER_DIR environment variable. All in all, this is what I did:
- Add
export GNOME22_USER_DIR="$HOME/.config/nemo" to ~/.profile.
- Create an empty file
~/.config/nemo/accels/nemo.
- Restart the System, start Nemo, close Nemo.
- The file created in 2. now should have been filled with all available actions. If not, see below list.
- Edit the desired lines, remove the comment character (
;) and spaces from the start. Save your changes in a backup. Nemo sometimes seems to overwrite that file partially.
- Restart the system.
For reference, this is what Nemo currently writes into that file on my system (As you see, it also lists user scripts):
; nemo GtkAccelMap rc-file -*- scheme -*-
; this file is an automated accelerator map dump
; (gtk_accel_path "<Actions>/ShellActions/New Window" "<Primary>n")
; (gtk_accel_path "<Actions>/ShellActions/Sidebar List" "")
; (gtk_accel_path "<Actions>/ShellActions/File" "")
; (gtk_accel_path "<Actions>/IconViewActions/Sort by Size" "")
; (gtk_accel_path "<Actions>/DirViewActions/OpenAlternate" "<Primary><Shift>o")
; (gtk_accel_path "<Actions>/DirViewActions/RenameSelectAll" "<Shift>F2")
; (gtk_accel_path "<Actions>/ShellActions/Show Hide Menubar" "")
; (gtk_accel_path "<Actions>/ShellActions/Zoom In" "<Primary>plus")
; (gtk_accel_path "<Actions>/DirViewActions/Cut" "<Primary>x")
; (gtk_accel_path "<Actions>/ShellActions/Go to Computer" "")
; (gtk_accel_path "<Actions>/DirViewActions/Create Link" "<Primary>m")
; (gtk_accel_path "<Actions>/DirViewActions/Redo" "<Primary>y")
; (gtk_accel_path "<Actions>/ShellActions/CompactView" "<Primary>3")
; (gtk_accel_path "<Actions>/ShellActions/Add Bookmark" "<Primary>d")
; (gtk_accel_path "<Actions>/ShellActions/Preferences" "")
; (gtk_accel_path "<Actions>/ClipboardActions/Copy" "<Primary>c")
; (gtk_accel_path "<Actions>/ScriptsGroup/script_file:\\s\\s\\shome\\snils\\s.local\\sshare\\snemo\\sscripts\\smake_folder_starter.py" "")
; (gtk_accel_path "<Actions>/IconViewActions/Reversed Order" "")
; (gtk_accel_path "<Actions>/ShellActions/TabsPrevious" "<Primary>Page_Up")
; (gtk_accel_path "<Actions>/DirViewActions/OpenAccel" "<Alt>Down")
; (gtk_accel_path "<Actions>/DirViewActions/Delete" "")
; (gtk_accel_path "<Actions>/DirViewActions/No Templates" "")
; (gtk_accel_path "<Actions>/DirViewActions/LocationDelete" "")
; (gtk_accel_path "<Actions>/ShellActions/Stop" "")
; (gtk_accel_path "<Actions>/DirViewActions/New Documents" "")
; (gtk_accel_path "<Actions>/DirViewActions/LocationCopy" "")
; (gtk_accel_path "<Actions>/ShellActions/Go" "")
; (gtk_accel_path "<Actions>/ShellActions/Close" "<Primary>w")
; (gtk_accel_path "<Actions>/DirViewActions/Connect To Server Link" "")
; (gtk_accel_path "<Actions>/DirViewActions/Location Eject Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/Stop Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/LocationRestoreFromTrash" "")
; (gtk_accel_path "<Actions>/ShellActions/Tab9" "<Alt>0")
; (gtk_accel_path "<Actions>/DirViewActions/Location Unmount Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/OpenAsRoot" "")
; (gtk_accel_path "<Actions>/IconViewActions/Sort by Name" "")
; (gtk_accel_path "<Actions>/IconViewActions/Keep Aligned" "")
; (gtk_accel_path "<Actions>/DirViewActions/Poll" "")
; (gtk_accel_path "<Actions>/ShellActions/Edit" "")
; (gtk_accel_path "<Actions>/ShellActions/Zoom Out" "<Primary>minus")
; (gtk_accel_path "<Actions>/ShellActions/Tab8" "<Alt>9")
; (gtk_accel_path "<Actions>/ShellActions/Go to Network" "")
; (gtk_accel_path "<Actions>/ShellActions/Show Thumbnails" "")
; (gtk_accel_path "<Actions>/DirViewActions/OpenInNewTab" "<Primary><Shift>t")
; (gtk_accel_path "<Actions>/DirViewActions/OtherApplication2" "")
; (gtk_accel_path "<Actions>/DirViewActions/Move to next pane" "")
; (gtk_accel_path "<Actions>/ShellActions/NemoShortcuts" "<Primary>F1")
; (gtk_accel_path "<Actions>/ShellActions/Back" "<Alt>Left")
; (gtk_accel_path "<Actions>/ShellActions/Bookmarks" "")
; (gtk_accel_path "<Actions>/DirViewActions/Select Pattern" "<Primary>s")
; (gtk_accel_path "<Actions>/DirViewActions/Open With" "")
; (gtk_accel_path "<Actions>/ShellActions/Tab7" "<Alt>8")
; (gtk_accel_path "<Actions>/DirViewActions/BrowseMoveTo" "")
; (gtk_accel_path "<Actions>/DirViewActions/OtherApplication1" "")
; (gtk_accel_path "<Actions>/ShellActions/TabsMoveLeft" "<Primary><Shift>Page_Up")
; (gtk_accel_path "<Actions>/DirViewActions/Location Start Volume" "")
; (gtk_accel_path "<Actions>/ShellActions/Tab6" "<Alt>7")
; (gtk_accel_path "<Actions>/DirViewActions/Properties" "<Alt>Return")
; (gtk_accel_path "<Actions>/ShellActions/Home" "<Alt>Home")
; (gtk_accel_path "<Actions>/ShellActions/Go to Trash" "")
; (gtk_accel_path "<Actions>/DirViewActions/Location Poll" "")
; (gtk_accel_path "<Actions>/DirViewActions/Location Stop Volume" "")
; (gtk_accel_path "<Actions>/ShellActions/Show Hide Sidebar" "F9")
; (gtk_accel_path "<Actions>/DirViewActions/Mount Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/Copy to Home" "")
; (gtk_accel_path "<Actions>/ShellActions/Tab5" "<Alt>6")
; (gtk_accel_path "<Actions>/DirViewActions/Move to Desktop" "")
; (gtk_accel_path "<Actions>/DirViewActions/Reset to Defaults" "")
; (gtk_accel_path "<Actions>/DirViewActions/LocationOpenInNewTab" "")
; (gtk_accel_path "<Actions>/IconViewActions/Sort by Detailed Type" "")
; (gtk_accel_path "<Actions>/ShellActions/Tab4" "<Alt>5")
; (gtk_accel_path "<Actions>/DirViewActions/OpenInTerminal" "")
; (gtk_accel_path "<Actions>/DirViewActions/CopyToMenu" "")
; (gtk_accel_path "<Actions>/ShellActions/Forward" "<Alt>Right")
; (gtk_accel_path "<Actions>/ShellActions/Tab3" "<Alt>4")
; (gtk_accel_path "<Actions>/ShellActions/About Nemo" "")
; (gtk_accel_path "<Actions>/IconViewActions/Clean Up" "")
; (gtk_accel_path "<Actions>/DirViewActions/Open" "<Primary>o")
; (gtk_accel_path "<Actions>/ShellActions/TabsMoveRight" "<Primary><Shift>Page_Down")
; (gtk_accel_path "<Actions>/ShellActions/IconView" "<Primary>1")
; (gtk_accel_path "<Actions>/ShellActions/View" "")
; (gtk_accel_path "<Actions>/IconViewActions/Sort by Modification Date" "")
; (gtk_accel_path "<Actions>/DirViewActions/Select All" "<Primary>a")
; (gtk_accel_path "<Actions>/ShellActions/Tab2" "<Alt>3")
; (gtk_accel_path "<Actions>/DirViewActions/LocationTrash" "")
; (gtk_accel_path "<Actions>/DirViewActions/Unmount Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/LocationPasteFilesInto" "")
; (gtk_accel_path "<Actions>/ShellActions/Tab0" "<Alt>1")
; (gtk_accel_path "<Actions>/DirViewActions/Eject Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/OpenContainingFolder" "<Primary><Alt>o")
; (gtk_accel_path "<Actions>/ShellActions/Tab1" "<Alt>2")
; (gtk_accel_path "<Actions>/DirViewActions/Pin File" "<Primary><Shift>d")
; (gtk_accel_path "<Actions>/DirViewActions/Duplicate" "")
; (gtk_accel_path "<Actions>/ShellActions/Edit Location" "<Primary>l")
; (gtk_accel_path "<Actions>/DirViewActions/LocationProperties" "")
; (gtk_accel_path "<Actions>/ShellActions/Help" "")
; (gtk_accel_path "<Actions>/ShellActions/Close All Windows" "<Primary>q")
; (gtk_accel_path "<Actions>/ShellActions/Show Hide Toolbar" "")
; (gtk_accel_path "<Actions>/DirViewActions/Copy to Desktop" "")
; (gtk_accel_path "<Actions>/DirViewActions/Self Eject Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/Rename" "F2")
; (gtk_accel_path "<Actions>/ShellActions/SplitViewNextPane" "F6")
; (gtk_accel_path "<Actions>/DirViewActions/Unfavorite File" "")
; (gtk_accel_path "<Actions>/DirViewActions/Empty Trash" "")
; (gtk_accel_path "<Actions>/ShellActions/Show Hide Statusbar" "")
; (gtk_accel_path "<Actions>/ShellActions/Connect to Server" "")
; (gtk_accel_path "<Actions>/ShellActions/Go to Templates" "")
; (gtk_accel_path "<Actions>/ShellActions/New Tab" "<Primary>t")
; (gtk_accel_path "<Actions>/ShellActions/NemoHelp" "F1")
; (gtk_accel_path "<Actions>/DirViewActions/FollowSymbolicLink" "")
; (gtk_accel_path "<Actions>/ShellActions/ZoomOutAccel" "<Primary>KP_Subtract")
; (gtk_accel_path "<Actions>/ShellActions/ZoomInAccel2" "<Primary>KP_Add")
; (gtk_accel_path "<Actions>/IconViewActions/Manual Layout" "")
; (gtk_accel_path "<Actions>/ShellActions/Edit Bookmarks" "<Primary>b")
; (gtk_accel_path "<Actions>/DirViewActions/New Empty Document" "")
; (gtk_accel_path "<Actions>/ShellActions/NemoPluginManager" "<Alt>p")
; (gtk_accel_path "<Actions>/DirViewActions/Start Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/Unpin File" "<Primary><Shift>d")
; (gtk_accel_path "<Actions>/DirViewActions/Self Start Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/Undo" "<Primary>z")
; (gtk_accel_path "<Actions>/ShellActions/TabsNext" "<Primary>Page_Down")
; (gtk_accel_path "<Actions>/IconViewActions/Arrange Items" "")
; (gtk_accel_path "<Actions>/IconViewActions/Sort by Trash Time" "")
; (gtk_accel_path "<Actions>/ClipboardActions/Select All" "<Primary>a")
; (gtk_accel_path "<Actions>/DirViewActions/Self Poll" "")
; (gtk_accel_path "<Actions>/DirViewActions/New Folder" "<Primary><Shift>n")
; (gtk_accel_path "<Actions>/DirViewActions/Location Mount Volume" "")
; (gtk_accel_path "<Actions>/ShellActions/Reload" "<Primary>r")
; (gtk_accel_path "<Actions>/DirViewActions/Restore From Trash" "")
; (gtk_accel_path "<Actions>/DirViewActions/MoveToMenu" "")
; (gtk_accel_path "<Actions>/DirViewActions/Favorite File" "")
; (gtk_accel_path "<Actions>/ShellActions/Up" "<Alt>Up")
; (gtk_accel_path "<Actions>/DirViewActions/OpenCloseParent" "<Shift><Alt>Down")
; (gtk_accel_path "<Actions>/DirViewActions/Paste Files Into" "")
; (gtk_accel_path "<Actions>/DirViewActions/Copy to next pane" "")
; (gtk_accel_path "<Actions>/ShellActions/Zoom Normal" "<Primary>0")
; (gtk_accel_path "<Actions>/ShellActions/Search" "<Primary>f")
; (gtk_accel_path "<Actions>/DirViewActions/Self Unmount Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/Move to Home" "")
; (gtk_accel_path "<Actions>/DirViewActions/Self Mount Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/PropertiesAccel" "<Primary>i")
; (gtk_accel_path "<Actions>/DirViewActions/Self Stop Volume" "")
; (gtk_accel_path "<Actions>/DirViewActions/Paste" "<Primary>v")
; (gtk_accel_path "<Actions>/ClipboardActions/Paste" "<Primary>v")
; (gtk_accel_path "<Actions>/DirViewActions/LocationOpenAlternate" "")
; (gtk_accel_path "<Actions>/ShellActions/ListView" "<Primary>2")
; (gtk_accel_path "<Actions>/DirViewActions/BrowseCopyTo" "")
; (gtk_accel_path "<Actions>/ShellActions/Sidebar Places" "")
; (gtk_accel_path "<Actions>/ShellActions/Show Hidden Files" "<Primary>h")
; (gtk_accel_path "<Actions>/DirViewActions/LocationCut" "")
; (gtk_accel_path "<Actions>/ClipboardActions/Cut" "<Primary>x")
; (gtk_accel_path "<Actions>/ShellActions/SplitViewSameLocation" "<Alt>s")
; (gtk_accel_path "<Actions>/DirViewActions/Copy" "<Primary>c")
; (gtk_accel_path "<Actions>/ShellActions/Sidebar Tree" "")
; (gtk_accel_path "<Actions>/DirViewActions/Trash" "")
; (gtk_accel_path "<Actions>/ShellActions/ZoomInAccel" "<Primary>equal")
; (gtk_accel_path "<Actions>/IconViewActions/Sort by Type" "")
; (gtk_accel_path "<Actions>/DirViewActions/Invert Selection" "<Primary><Shift>i")
; (gtk_accel_path "<Actions>/ShellActions/Show Hide Extra Pane" "F3")
References: 1, 2, 3, 4
