I have an NTFS partition that I want to automatically mount so I do not have to open Nautilus and click on it under Devices. If I mount with Nautilus, and then type mount, I see the following line:
/dev/sdb1 on /media/Data type fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
I am the owner of all files and permissions are the way I want them (have umask 077 in .bashrc). However, after following the instructions on MountingWindowsPartitions, and adding the following line to fstab
UUID=4A92C07A92C06C4F /media/Data ntfs-3g defaults,windows_names,locale=en_GB.utf8 0 0
the drive does indeed automatically mount, but all file permissions are -rwxrwxrwx and user and group are both root. The mount command now shows
/dev/sdb1 on /media/Data type fuseblk (rw,nosuid,nodev,allow_other,blksize=4096)
How do I specify the parameters in fstab so that the partition is mounted exaclty the same way as when I click on the device under Devices in Nautilus? I have Ubuntu 12.04.
DustByte
  • 651
The fuse mounting done by nautilus has one advantage over system-wide mounts in /etc/fstab: it knows which user is doing the mounting. Assuming you are the only user of your client machine (which is fair enough these days), you can get your numeric UID and GID and default umask with:
$ id
uid=1001(msw) gid=1001(msw) groups=…
$ umask
0002
then you'd add these to the options group in fstab
defaults,uid=1001,gid=1001,umask=077,windows_names,locale=…
it would be wise, but not required to replace defaults with
auto,rw,nosuid,nodev,noexec
nautilus assumes that a user mounted partition is "untrusted" so flags them this way. A foreign (i.e. NTFS) partition should probably always be viewed with such suspicion.
added in response to comment:
This is an area where cross-system semantics get weird. The mount.ntfs(8) manual defines fmask and dmask to try to make files created on an NTFS filesystem behave better. Can I ls a directory not owned by me under windows? Should I be able to? Is there any relation between your UID on Linux and Windows? Dunno.
There is a usermapping= option for mount.ntfs which supersedes uid, gid, umask, fmask, and dmask. I suggest you look into that if you want fine control on what files are assigned what permissions. I would check to see that you can even access them from the Windows side before committing too much under a usermapping mount.
msw
  • 4,696
