I have an ATI 4650 graphics card. And when i install the proprietary driver - there are glitches and blackness all over the screen. I've also read somewhere that ati cards don't work with 11.04 yet. Is it true? When will i be able to test 11.04 then?
P.S. By not working i mean - Unity doesn't work. The classic gnome shell works fine.
Jorge Castro
  • 73,717
7 Answers7
The open driver work from the archive (that gets set up by default) generally works on my ATI Fusion-based laptop. It's decently fast but not as fast as fglrx.
The fglrx drivers in the archive were faster, but would freeze my laptop once every few hours. The Catalyst 11.4 drivers that I manually installed from their website are the fastest and I've had no crashes yet.
Some people are reporting that disabling vsync has helped them:
Jorge Castro
  • 73,717
It works with the open source driver.
I think the package name is xserver-xorg-video-ati
I also think you need to completely uninstall the binary driver.
Here are instructions from the ubuntu wiki about how to remove the binary driver and install the open source one
To quote it:
sudo /usr/share/ati/fglrx-uninstall.sh  # (if it exists)
sudo apt-get remove --purge fglrx*
sudo apt-get remove --purge xserver-xorg-video-ati xserver-xorg-video-radeon
sudo apt-get install xserver-xorg-video-ati
sudo apt-get install --reinstall libgl1-mesa-glx libgl1-mesa-dri xserver-xorg-core
sudo dpkg-reconfigure xserver-xorg
Then reboot.
hasen
  • 1,292
i have a 4650mobility working in natty with fglrx ( atis proprietary driver ).
Notice : you MUST use the fglrx driver from within nattys repo and NOT use the *.run installers from amd.com/ati.com. The one in natty is a special pre-build version that can handle the new kernel and xserver.
Limitations : You cannot use unity or compiz , but unity-2d which gives you a similar experience,the dock and the globalmenu plus the ubuntu launcher :
Do this :
If you want to improve the look and feel to resemble unity3d closer you can activate metacitys own composite feature in gconf.This gives shadows and blur. Optional of course.
I had glitches with the proprietary drivers after upgrading to 11.04. But the open source ones are working brilliantly in 11.04 with my ATI HD 5750 and 27" display (they didn't work at all on 10.10 for me). So there's a decent chance that it will work! Maybe try it out on USB first
Felix
  • 453
My computer is a core i7 with ati HD 5000 series, and the unity interface run with a lot lags
i install the ".run"
i run: /usr/lib/nux/unity_support_test -p
OpenGL vendor string:   ATI Technologies Inc.
OpenGL renderer string: ATI Mobility Radeon HD 5400 Series
OpenGL version string:  4.1.10666 Compatibility Profile Context
Not software rendered:    yes
Not blacklisted:          yes
GLX fbconfig:             yes
GLX texture from pixmap:  yes
GL npot or rect textures: yes
GL vertex program:        yes
GL fragment program:      yes
GL vertex buffer object:  yes
GL framebuffer object:    yes
GL version is 1.4+:       yes
Jorge Castro
  • 73,717
Leo
I have XFX HD-585X-ZAFC Radeon HD 5850 with i5-2500K and everything installed and working correctly.
Max
I use the amd64 architecture, and my VGA card is the RV710 Radeon HD 4550.
For me an fglrx seg fault in firegl_SetSuspectResumeState caused X to not even start up. After updating to Natty, I would get only an 80x25 text login: prompt.
I found the same links mentioned above to expunge fglrx and replace it with the open-source ATI driver. I also had to remove /etc/X11/xorg.conf.
This made it possible for the X login screen to appear, and I could log in using the "Ubuntu Classic (No effects)" option (i.e., Metacity window manager). All attempts to use Compiz, required for Ubuntu Classic or the Unity desktop, fail badly.
I have not been able to solve this problem at all.
Mojo
Mojo
  • 153
