I've got a locale problem.
The collating sequence in nautilus and other programs has changed.
I get locale errors appearing in the terminal when I launch a GUI app..
Gtk-WARNING **: Locale not supported by C library.
Using the fallback 'C' locale.
The locale command produces error messages
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
LANG=en_AU
LANGUAGE=en_AU:en
LC_CTYPE="en_AU"
LC_NUMERIC="en_AU"
LC_TIME="en_AU"
LC_COLLATE=en_AU.UTF-8
LC_MONETARY="en_AU"
LC_MESSAGES=en_AU.UTF-8
LC_PAPER="en_AU"
LC_NAME="en_AU"
LC_ADDRESS="en_AU"
LC_TELEPHONE="en_AU"
LC_MEASUREMENT="en_AU"
LC_IDENTIFICATION="en_AU"
LC_ALL=
As suggested in askubuntu question, I've run the following commands, but there was no change.
sudo apt-get install language-pack-en-base
sudo dpkg-reconfigure locales
I also tried the suggestion in askubuntu question... also no change.
apt-get install --reinstall locales
I think it began when I temporarily installed and uninstalled the Urdu language Input Method Editor via IBus .. it certainly happened on the same day.
Maybe it is IBus related, but I've not had any problems with it before this.
- The OS is 10.04
