I had Windows and installed Ubuntu 12.10 alongside Windows.
I want to allocate suitable disk space to Ubuntu. I installed the Gparted Parition Editor from the Software Center.
My problem is: It closes down as soon as I open it.The same happens when I try to open it through Terminal.
This is the message I get in the terminal:
(process:2977): Gtk-WARNING **: Locale not supported by C library.
    Using the fallback 'C' locale.
libparted : 2.3
(gpartedbin:2977): glibmm-ERROR **:
unhandled exception (type std::exception) in signal handler:
what: locale::facet::_S_create_c_locale name not valid
Trace/breakpoint trap (core dumped)
This is the result of sudo fdisk -l:
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x7434793e
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1              63       80324       40131   de  Dell Utility
Partition 1 does not start on physical sector boundary.
/dev/sda2   *       81920    29044735    14481408    7  HPFS/NTFS/exFAT
/dev/sda3        29044736   606384127   288669696    7  HPFS/NTFS/exFAT
/dev/sda4       606386176  1953521663   673567744    f  W95 Ext'd (LBA)
/dev/sda5       606388224   817569791   105590784    7  HPFS/NTFS/exFAT
/dev/sda6       817571840  1543921663   363174912    7  HPFS/NTFS/exFAT
/dev/sda7      1543923712  1748721663   102398976    7  HPFS/NTFS/exFAT
/dev/sda8      1748723712  1953521663   102398976    7  HPFS/NTFS/exFAT
sudo parted -l:
Model: ATA WDC WD10JPVT-75A (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Number  Start   End     Size    Type      File system  Flags
 1      32.3kB  41.1MB  41.1MB  primary   fat16        diag
 2      41.9MB  14.9GB  14.8GB  primary   ntfs         boot
 3      14.9GB  310GB   296GB   primary   ntfs
 4      310GB   1000GB  690GB   extended               lba
 5      310GB   419GB   108GB   logical   ntfs
 6      419GB   790GB   372GB   logical   ntfs
 7      790GB   895GB   105GB   logical   ntfs
 8      895GB   1000GB  105GB   logical   ntfs
user98085
  • 1,611
