I would like to just use Ubuntu from now on, I don't want to go back to windows unless I have to. The problem being, I have a few documents that I need to work on in Microsoft Word. Can someone give me directions on how to open them through Ubuntu?
In this Wiki article, it says that Microsoft Office documents saved as a .doc or a .docx file can be opened in LibreOffice. Therefore, you should be able to just open it. Just copy the files onto a flash drive and then in Ubuntu, double click the .doc or .docx file to open it in LibreOffice.
Edit: When opening .doc or .docx files in LibreOffice, be aware that the formatting can be a little off in some cases, so sometimes when opening a MS Word file in LibreOffice it does not look as it was intended/how it would have looked in MS Word.. Thanks to Shaun for pointing that out.
- 1,176
Open LibreOffice Writer, hit "Open" (or do CTRL+O), and navigate to where you saved the file.
Or, just double click the .doc or .docx file.
Either of those methods should be able to open the file.
- 78,878
Copy the files from within Windows on a USB stick or put them on a network share you can get too from Ubuntu.
Open them with the "open" dialog inside LibreOffice. Nowadays LibreOffice will open .DOC (and .XLS) files without much difficulty.
The only thing LO can not do for you macro's. Those tend to be created in Visual Basic.
- 309,379
This has been answered in exquisite detail here. You can just boot into Ubuntu and open files by a simple double-click, and the only difference you'll ever notice is that you're using LibreOffice.
And if you're truly nostalgic about MS Office, the above link will show you how to get that running on Ubuntu.
