I tried opening Trash by running the command nautilus, but it gives me an error.
Asked
Active
Viewed 2.1e+01k times
65
Zanna
- 72,312
Suhas Shetty
- 769
90
The trash folder should be located under:
/home/your_username/.local/share/Trash
So you should be able to access it via:
cd ~/.local/share/Trash
The folder might not exist unless you delete something from the filesystem. In this case you would run into an error (saying that the folder does not exist).
29
If you want to open Trash using Nautilus run the following:
nautilus trash://
Liam Baker
- 129
Eric Carvalho
- 55,453
14
For Ubuntu 18.04 and newer, use gio. For older versions, use gvfs-ls and gvfs-trash.
To read the trash:
gio list trash://
gvfs-ls trash://
To send files or directories to the trash:
gio trash [FILE or DIR]
gvfs-trash [FILE or DIR]
To empty it:
gio trash --empty
gvfs-trash --empty
wjandrea
- 14,504
You can list all the files in the trash by using trash-list. First, install it by running:
sudo apt install trash-cli
Now, you can list the files by running:
trash-list
You may be interested in these other commands too:
| Command | Description |
trash-restore |
Restore file from trash. |
trash |
Command line trash utility. |
trash-empty |
Empty trash. |
trash-list |
List trashed files. |
trash-put |
Put file in trash |
trash-rm |
Removes files matching a pattern from the trash can. |
Flimm
- 44,031
