13
I have run the following commands:
sudo groupadd -r testgroup
sudo useradd -g testgroup -M -r testuser
Notice the -r option, which according to the man page:
-r
    Create a system account.
Assuming I have a user account with root privileges, I then run:
sudo -u testuser cat /dev/input/mouse0
However, I get:
cat: /dev/input/mouse0: Permission denied
Running the same command as root provides the expected output (garbled output from the mouse driver).
How can I create a user with root privileges?
Marco Ceppi
  • 48,827
Nathan Osman
  • 32,495
5 Answers5
22
Haven't tried it but this should create a new user and add them to the sudo group, which if your /etc/sudoers is as default, should mean they're allowed to use sudo with their password (just like the standard first user):
sudo adduser --group sudo newusername
If you've already created the user, you can just run:
sudo adduser existing_user sudo
man adduser will show you some of the other billion permutations and combinations of arguments this tool has.
Note: If you use Ubuntu 11.10 or older, you should use the admin group instead of sudo.
Eliah Kagan
  • 119,640
Oli
  • 299,380
I found some sites where they do the: sudo adduser paul admin
but my linux does not have the admin group so I use:
sudo adduser paul sudo
devav2
  • 37,290
Papi
  • 31
"System account" just means that the user will get an UID (user identifier) from a reserved range, it doesn't give any extra permissions. The right way to elavate privileges is to use sudo, as described by Oli.
Adam Byrtek
  • 9,861
The following worked on Ubuntu 16.04 LTS:
sudo adduser robert && sudo adduser robert sudo
Creates the user and adds him/er to the sudoer list
Justas
  • 211
sudo usermod -a newuser -G sudo
