I accidentally made my DPI settings really really large and now I can't change them back to a smaller setting because it's so large that it's not visible on my screen to fix it. Is there a way to correct DPI settings in the Command Line???
edit: Font DPI
Kristen
  • 71
To change the Font DPI in the terminal (default is 1.0)
gsettings set org.gnome.desktop.interface text-scaling-factor 1.0
If you are talking about changing the screen DPI then you can follow the directions for:
How to find and change the screen DPI?
bigbash
  • 281
If you're using Linux Mate DE, this worked for me:
dconf write "/org/mate/desktop/font-rendering/dpi" "132.0"
The decimal place is very important, for some reason it won't work without it. It will set it to default value.
Also if you wanna read the existing values:
dconf read "/org/mate/desktop/font-rendering/dpi"
dconf list "/org/mate/desktop/font-rendering/"
