Please I need help.
Objective: Be able to create a Wifi-Hotspot on my laptop[Dell Inspiron 5520 64-bit with Ubuntu 12.04 LTS] and share the internet connection being supplied via my USB Internet Wireless Broadband Dongle [ZTE Reliance Netconnect] with my android smartphone and other laptops at home.
Progress so far: 1. I am able to use my dongle conveniently after configuring it using wvdial.
  1. I tried setting up an "New Wireless Network" ad-hoc but the sharing did not work. In fact my phone wasn't able to connect to this network.
  2. I saw other Similar Posts on AskUbuntu and most of them are based on sharing a "Wired" Connection which doesn't help my case. In fact, one similar question was flagged duplicate even though the person had clearly mentioned he needs an answer for "Wireless" connection such as myself.
  3. when I use "iwconfig" I get the following, is this correct?
    $ iwconfig ppp0 no wireless extensions.
    eth0 no wireless extensions.
    eth2 IEEE 802.11abg ESSID:off/any
    Mode:Managed Access Point: Not-Associated
    Retry long limit:7 RTS thr:off Fragment thr:off Power Management:off
    lo no wireless extensions.
How can I achieve this? Please someone guide me step-by-step. Thanks :)
Seth
  • 59,332
To re-broadcasting your internet via wireless you should have a Wireless ethernet card that supports Master Mode.
Suggest you check with Dell Support (you must do this for they will ask for your Product Code) to see if the wireless card included with your Dell supports Master Mode. Their chat is at http://www.dell.com/learn/campaigns/chat-splitter-us
This askubuntu question cover both wired and mobile broadband, but from comments it seems to be outdated. This describes how to configure mobile broadband (via a USB dongle or other ppp based) then re-broadcasting this via wireless or wired ethernet.
totti
  • 6,908
  • 40
  • 48
