I have an extracted copy of Ubuntu 13.04 iso (live CD), but if I burn it directly it will not boot. Is there any way to create a bootable iso so that I can burn it to a DVD or USB flash drive?
I tried ISO Master, but it first wanted an iso and allows me to add some more files. Can I use it to create iso only from extracted folders?
karel
  • 122,292
  • 133
  • 301
  • 332
7 Answers7
An ISO if extracted, will loose it's capability to boot. Building ISO from this extracted files need to done in a special manner to set booting flag and other parameter
You just point your burning software to ISO (not extracted) , then the dvd/cd will be bootable.
If you want to customize ubuntu ISO, please see How to customize the Ubuntu Live CD?
To rebuilt from folder content, you can do so using powerISO (if on windows). Here is tutorial that may help you.. This option should be available with all standard burning software. Just check the manual.
Web-E
  • 21,716
To make an ISO from files on your hard drive, you can use the mkisofs command. To use it, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
mkisofs -o /home/user/Desktop/test/Ubuntu.iso /home/user/Desktop/test
(Using the command above, I have a folder called test in the Desktop folder, which will create the ISO in the same test folder, using only the files in the test folder).
Once created, then you can burn it to a DVD.
Note: This will not create a bootable DVD. To create a bootable DVD you need to get ISOLINUX, and you still can use mkisofs.
Mitch
  • 109,787
Web-E already gave a very good answer with the PowerISO tutorial.
As an alternative solution, I've found an interesting answer there:
https://www.nextofwindows.com/how-to-re-create-a-bootable-iso-from-extracted-windows-installation-files
It's for Windows, but as this solution is very easy, it probably worths creating a small Windows booting disk, or use the mini XP Windows included in Hiren's boot live CD. I don't know if it's feasible, it has to be tested to answer this question, but the software used here, imgburn is compatible XP.
Considering you didn't touch anything in your files or folders of your extracted ISO, as it's obvious you cannot create bootable ISO from any kind of files or folder (bootable files that will pass important info to the bootloader are needed).
In the example, they use ImgBurn (Windows) with "create image files from files or folders". Ignore the parts regarding Windows files (like ei.cfg) as we aren't trying to make a bootable Windows.
They turned a bunch of .dll files and other formats, to an ISO file, and checked “Make Image Bootable“ in the section called Advanced → Bootable Disc.
So, it's exactly what you want to do, turning a bunch of files and folders, with any formats, to an ISO, and giving the ISO the instrinsic "bootable" property.
Once again, it won't be bootable if the ISO from which you extracted the files wasn't already a bootable OS type.
There are other software able to do the same: Winiso (their tuto is badly explained, but we see on the image that they used files and folders to construct their bootable ISO),
Additional hints:
Alternatively, if everything fails, software like AnytoISO to create an ISO from any kind of files, and using another sofware to make the ISO bootable, it can be made from the command line, or from a software.
One way to check if your extracted folders are able to boot is to extract the bootable file from it. They use UltraISO for that here, “Bootable > Extract Boot File from CD/DVD”.
I didn't test, but I imagine that if there's not boot-file in your folders, it may return an error message.
Quidam
  • 141
  • 13
The best option i can think of is to download Poweriso and extract it straight to the dvd. It should already be bootable after that. Did u delete the original iso and all you have is the extracted version? Sorry the only way i know is to have the iso, im not sure how if it is already extracted.
Jake
If your system has grub installed, you do not need a DVD/usb to boot.
Put your iso in the hard disk and modify the grub menu; this also lets you boot from an iso.
Why do you need to extract files from the iso?
I use (http://unetbootin.sourceforge.net/) - been using it for years to burn iso's to usb. To create an ISO file:
Open Terminal. Navigate to the directory you want to create the ISO in. then:
mkisofs –o thefilename.iso /home/thepath/2/thefolder/ofthe/extractedfiles
gingamann
  • 393
-1
I think the best way is to use Linux Live USB Creator to boot your USB from ubuntu .iso file.
you can download the .exe file from here and if you want to use it in ubuntu, I thimk you can run it with wine
Hossein Shahsahebi
  • 203
