I had a problem mounting an NTFS partition using pysdm that's discussed here -
can't mount ntfs partition without root access
I resolved it by the fstab edits suggested. However, I now get an "error mount 0 - skip or fix now?" (paraphrased from memory) message on startup. "Skip" boots normally and everything mounts correctly. I have found these messages in the kernel log -
26/07/13 11:27:25 EXT4-fs (sda6) warning: maximal mount count reached, running e2fsck is recommended
26/07/13 11:27:25 EXT4-fs (sda6) mounted filesystem with ordered data mode. Opts: (null)
This is my current /etc/fstab -
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/sda8 during installation
UUID=[id###] / ext4 errors=remount-ro 0 1
# swap was on /dev/sda7 during installation
UUID=[id###] none swap sw 0 0
/dev/sda5 /media/data ntfs
nls=iso8859-1,rw,umask=000,user 0 0
/dev/sda6 /media/ext4-data ext4 defaults 0 0
This is the only part I manually edited -
This line is residue from pysdm -
Did I cause this error or is there some configurable mount setting I am unaware of?
EDIT: This is screencap of fstab showing the split line for sda5 -
