My Bluetooth is not working in Ubuntu 13.04. I am unable to turn it on and also, Bluetooth icon doesn't show up in the top bar.
I asked about this on #ubuntu IRC and they said that I am missing the proprietary drivers for it. There is nothing under Additional Drivers in Software and Updates
Bluetooth does work 'Try Ubuntu mode' when I boot Ubuntu from DVD/USB.
How can I get the required drivers?
Sourabh
  • 1,911
If your Ralink Bluetooth devices is a RT3290, then you can follow this instructions:
  1. Download this .zip archive from public folder:
    http://downloads.zotac.com/mediadrivers/mb/download/NB087_Ubuntu.zip
  2. Unzip it to any directory, cd $PATH-OF-YOUR-DOWNLOAD/NB087_Ubuntu/rtbth_v3.9.3/rtbth_v3.9.3/ and make bluetooth module:
    sudo make
    sudo mkdir /etc/Wireless/RT3290
    ...then copy necessary files in specified directory like this:
    sudo cp rtbth.ko /etc/Wireless/RT3290/
    sudo cp rtbt.bin /etc/Wireless/RT3290/ ; sudo chmod +x /etc/Wireless/RT3290/rtbt.bin
    sudo cp 49rtbt /usr/lib/pm-utils/sleep.d/
  3. Create startup script like this:
    sudo nano /etc/init/bluetooth.sh ; sudo chmod +x /etc/init/bluetooth.sh
    ...past this into editor field and save:
    #!/bin/bash
    insmod /etc/Wireless/RT3290/rtbth.ko
    mknod /dev/rtbth c 192 0
    exit 0
    ..then edit your /etc/rc.local (do this with sudo) and add line /etc/init/bluetooth.sh before exit 0 line. This must look like this:
    #!/bin/sh -e
    /etc/init/bluetooth
    exit 0
  4. Test script by running and seek for errors:
    sudo /etc/init/bluetooth.sh
    Please do not forget to give execution flags and also for rtbt.bin.
  5. Re-login or reboot machine and look for bluetooth applet in your taskbar
This is a typical scenario for installing Ralink 3290 Bluetooth Drivers, but this special version works for 13.04 based Ubuntu kernels. Look for this article http://ubuntuforums.org/showthread.php?t=2115570 for typical bluetooth driver installing.
If you are facing compilation errors, try downloading the package with source code and compiling + installing it manually. To do this open a shell where you downloaded the source, unpack it, and run:
make
sudo make install
Then reboot.
Tested on 13.04, 3.10.9-031009-generic kernel, h/w Model: Pavilion 15-E016Tx product: RT3290 Bluetooth, vendor: Ralink corp
con-f-use
  • 19,041
