Is there a way to assign a value to a variable, that value which we get in terminal by writing any command?
Example command: sensors
From that we get CPU temperature. How can I assign this value to a temp_cpu variable?
Yes, you use my_var=$(some_command). For example:
$ foo=$(date)
$ echo $foo
Mon Jul 22 18:10:24 CLT 2013
Or for your specific example, using sed and grep to get at the specific data you want:
$ cpu_temp=$(sensors acpitz-virtual-0 | grep '^temp1:' | sed 's/^temp1: *//;s/ .*//')
$ echo $cpu_temp
+39.0°C
You can also store the value of command as follows:
variableName=`command`
$variableName
For example:
currentDirectory=`pwd`
$currentDirectory
