35
I recently installed LAMP on Ubuntu 13.04(32-bit) but forgot my phpMyAdmin password. How can I reset its password without re-installing it?
Seth
  • 59,332
Simply change or reset your MySQL root password by doing the following:
  1. Stop the MySQL server
    sudo service mysql stop
  2. Start mysqld
    sudo mysqld --skip-grant-tables &
  3. Login to MySQL as root
    mysql -u root mysql
  4. Change MYSECRET with your new root password
    UPDATE user SET Password=PASSWORD('MYSECRET') WHERE User='root'; FLUSH PRIVILEGES; exit;
  5. Kill mysqld
    sudo pkill mysqld
  6. Start mysql
    sudo service mysql start
  7. Login to phpmyadmin as root with your new password
Seth
  • 59,332
jctoledo
  • 1,589
38
You don't actually need to reset your username and password, if you can see them.
In your terminal window, type:
sudo -H gedit /etc/dbconfig-common/phpmyadmin.conf
This will open your phpmyadmin configurations.
There, you will see your username under dbc_dbuser='your_username' and password under dbc_dbpass='your_password'.
muru
  • 207,228
There is a workaround on Debian (Ubuntu, Mint, etc.) where there is a second admin account automatically generated by the system called
debian-sys-maint
You can see (and should not change) its password via
sudo nano /etc/mysql/debian.cnf
It is possible (sure on Ubuntu 16.04) to use that account both in phpMyAdmin as well as in the command line
mysql -u debian-sys-maint -p
The account has exactly the same privileges as phpMyAdmin's / MySQL's root.
Kulfy
  • 18,154
I was wondering why my login was failing even though I never changed the password.
It was failing because I rebootet the server and the mysql server was not startet automatically. So I startet the server and it worked again.
Black
  • 844
