I have read and attempted to follow every link for customizing Ubuntu's kernel including:
- Build Your Own Kernel - Ubuntu Wiki -# I started with this one and could not continue when I got to the step referencing
fakeroot /debian/rulesbecausedebiandirectory did not exist. - Kernel/Compile (last updated 3/5/2013) # Again, don't have
debianfolder - What's a simple way to recompile the kernel?
I get everything downloaded (except for the packages which no longer exist). But after that, I can't go any further:
I've downloaded source of all kernels for this release:
git clone git://kernel.ubuntu.com/ubuntu/ubuntu-precise.git
And moved it to the /usr/src/ubuntu-precise directory and although I could not locate or find the debian folder it was under /usr/src/ubuntu-precise/debian. Perhaps because I did not have the symbolic link?
Renamed the older version source directory and created a symbolic link for ubuntu-precise with the same name. This was in a book Ubuntu Unleashed Page 426.
I've downloaded/installed the build environment:
sudo apt-get build-dep linux-image-$(uname-r)
Following the directions on the second link above, I installed the packages indicated:
sudo apt-get install linux-kernel-devel fakeroot -kernel-wedge buid-essential
(linux-kernel devel not found) Removed and continued with others because it is
supposedly now part of the build-dep linux...etc.
this only installed fakeroot because all others were there.
Also installed:
sudo apt-get install crash kexec-tools makedumpfuile
sudo apt-get build-dep linux # which did not install or update
sudo apt-get install git-core libncurse5 libncurse5-dev libelf-dev asciidoc binutils-dev
sudo apt-get install kernel-package
sudo apt-get install ccaches
and last but not least
sudo apt-get install libnewt-dev # which was already there and did not install
Since I had now tried this several times, I had to:
$make-kpkg #to clean source directories
$make mrproper # to clean all subdirectories of source
restore the .config deleted by mrproper by copying it from /boot to /usr/src/ubuntu-precise. From source directory ubuntu-precise:
$sudo cp /boot/config-$(uname -r) ./.config # $(uname -r) checks current kernel and grabs it
$ make menuconfig # to open old config, make changes and save
$ fakeroot make-kpkg-j 2 --initrd --append-to-version=-jn kernel_image kernel_headers
where 2 = # of processors and -jn is appended to the deb to notate changed version
It is compiling right now, but I sincerely hope I don't receive an error. We sincerely need one GOOD set of instructions which instead of saying do this or that, explains what you are doing when you use the command and a wiki should be kept up to date.
