I gave permissions to read and write files in /var/www to the working user(me) through the steps given in Whats the simplest way to edit and add files to “/var/www”?. It works fine when I try to create/read file in the project directory.
Say I am working in /var/www/xyz
I am able to read and write files in this folder through a php code. Now, I have created a folder inside folder xyz, say abc
/var/www/xyz/abc
In my php code when I read a file situated inside abc, it works fine, but it gives me warning: permission denied when I try to create a file in this folder.
The exact warning is
Warning: fopen(abc/a.txt): failed to open stream: Permission denied in /var/www/xyz/code.php
I was asked to provide some output:
stat /var/www/dodge
  File var/www/dodge'
  Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: 700h/1792d Inode: 1445503 Links: 8
Access: (2775/drwxrwsr-x) Uid: ( 33/www-data) Gid: ( 33/www-data)
Access: 2013-07-16 16:29:21.434531583 +0530
Modify: 2013-07-16 14:07:46.482782580 +0530
Change: 2013-07-16 16:28:04.622533850 +0530
 Birth: -
stat /var/www/xyz/abc
  File: /var/www/dodge/codes'
Device: 700h/1792d Inode: 1446465 Links: 2
Access: (0775/drwxrwxr-x) Uid: ( 1000/ wq) Gid: ( 1000/ wq)
Access: 2013-07-16 15:16:15.554661170 +0530
Modify: 2013-07-16 15:13:42.698665686 +0530
Change: 2013-07-16 15:13:42.698665686 +0530
 Birth: -
vinit
  • 31
For this situation you need to add the set-group-ID bit on the directory /var/www/xyz so newly created directories inside inherit group from parent.
chmod g+s /var/www/xyz
See man 2 chmod
S_ISGID (02000) set-group-ID (set process effective group ID on execve(2); mandatory locking, as described in fcntl(2); take a new file's group from parent directory, as described in chown(2) and mkdir(2))
See comments to the answer from referred post.
Edit after comment:
If you added the setgid bit on the parent directory after the subdirectory was created:
  File var/www/dodge'
Change: 2013-07-16 16:28:04.622533850 +0530 <---added setgid
but the subdirectory was created before that:
Change: 2013-07-16 15:13:42.698665686 +0530 <---before ctime above
the setgid bit works when you create new files and directories. It will not work for any that have already been already created. So the codes directory is still owned by wq and group wq and the other user has no permission to create files there; that is why you get the same error as before. Either chown the subdirectory to set the correct group, or delete and recreate it.
chown :group /var/www/dodge/code
Zanna
  • 72,312
Solved this issue by adding the folder xyz to the group var-www. Thus, now I am able to write to the files in the sub-folders too
vinit
  • 31
