I downloaded the Ubuntu 13.04 32-bit image from ubuntu.com. I am trying to create a bootable image of USB drive.
Startup Disk Creator is able to recognize the USB correctly and automatically. When I choose the ISO by clicking on Other..., it doesn't throw any error, but the file does not appear in the Startup Disk Creator window.
The ISO is 705 MB in size and I am on 12.10. I tried creating an empty ISO file and it is not being recognized.
Can you please help me in this regard ? Thanks in advance.
edwin
  • 3,829
Try doing it another way. First, determine what device node your USB stick is (usually /dev/sdb unless you have another storage device plugged in or multiple hard drives).
(To verify, you can open the Disks application that comes with Ubuntu, find your disk and click it, then look right under it for the device node.)
All you have to do now is open a terminal with Ctrl+Alt+T and run
sudo  dd  if=/path/to/ubuntu.iso  of=/dev/sdX  bs=8M
where /path/to/ubuntu.iso is the actual path to the Ubuntu ISO and /dev/sdX is your USB stick device node. That never failed me.
edwin
  • 3,829
ooa
  • 667
I also encountered this bug. I don't know what causes it. I almost suspect foul play, because the application allows me to install an Ubuntu iso to a USB drive, but when I downloaded an OpenSUSE iso, it wouldn't recognize that. This makes me suspicious because I can't think of any good reason why the utility would work with one distro's iso and not the other, especially given that they were both in the same directory and had the same file permissions.
A workaround that is easy is to right-click the iso in the file manager and select "Open With Other Application" and then in the list, select "Disk Image Writer".
This worked for me. It is a completely different program that basically does the same thing.
cazort
  • 160
Cloning tools
The cloning method described in the answer by ovc is very reliable, when used correctly, and it works with all hybrid iso files. Most iso files of modern linux distros are iso files.
dd is a cloning tool. It is very powerful but also dangerous, because it does what you tell it to do without questions. So if you tell it to wipe the family pictures ... and it a small typing error away. It has earned the nickname 'data destroyer'.
Instead you can use tools, that perform the same task under the hood, but help you select the target device and double-check that it is the correct drive. Starting with Ubuntu 16.04 LTS, the Ubuntu Startup Disk Creator, alias usb-creator-gtk, uses the cloning method. Disks alias gnome-disks can also clone from an iso file to a target device, usually a USB pendrive or memory card. These two tools are built into Ubuntu.
There are also other cloning tools, that can be installed into Ubuntu or Windows. mkusb can clone iso files and compressed image files. It can also create persistent live drives, and it can restore a USB boot drive to a standard storage device after the installation.
Win32 Disk Imager is a cloning tool for Windows, that can help you create a USB boot drive with Ubuntu.
Extracting tools
There are also many tools, that can create USB boot drives by extracting the content of the iso file to another file system and install a bootloader to the target device. Several of these tools work well and can be recommended, for example Rufus and Unetbootin.
But when the boot structure of the iso file changes (in a new version of Ubuntu), these extracting tools will have problems, until they are modified to recognize and manage the new boot structure. Older versions of the Ubuntu Startup Disk Creator (before 16.04 LTS) are affected by several bugs because of modifications of the syslinux boot structure in BIOS mode.
sudodus
  • 47,684
