I have found a cure for this which has worked for me
- Ubuntu 13.04
- Packard Bell
- Intel® Core™ i3-2350M CPU @ 2.30GHz × 4
- Intel® Sandybridge Mobile
- 64-bit
THE ORIGINAL PROBLEM
The F11 and F12 control the brightness, but although the tooltips showed that the brightness was changing, the screen didn't change.
THE CURE
I cured this by opening and editing the grub menu.
- Open Terminal with Ctrl + Alt + T
- I typed in
sudo gedit /etc/default/grub, entered my password
- I changed the line which read
GRUB_CMDLINE_LINUX="" to GRUB_CMDLINE_LINUX="acpi_backlight=vendor"
- Saved and Closed gedit.
- in Terminal I updated the Grub with
sudo update-grub
- I re-booted the laptop
Everything is now working.
