My memory card was found yesterday, but I found the photos stored in it have gone, is it possible to restore them back? If so, how? Please recommend some affordable program and works for my memory card, thanks.
Photorec
This software is part of the testdisk
suite, specifically designed to recover images from a partially overwritten or otherwise damaged drive.
There is an extremely helpful step-by-step guide written by the makers of PhotoRec which I recommend you follow:
In case you have Ubuntu installed you can run PhotoRec in a terminal after installation of the TestDisk suite but you can also do so from a live system as further elaborated in my answer to the following questions:
We should try to recover our files from an image we created from the memory card by running the following command (see also this question) in a terminal:
sudo dd if=/dev/sdX of=/home/<user>/<path>/rescue.dd
Replace sdX with the appropriate value for your memory card, and replace /<user>/<path>/ with your path for the rescued file. Be extra careful to get the command right, dd is an advanced tool!
We can then recover files from this image with:
photorec rescue.dd
Deleted or lost files can sometimes be recovered from failed or formatted drives and partitions, CD-ROMs and memory cards using the free/libre software available in the Ubuntu repositories.
- 346
