sudo apt-get update && sudo apt-get install netflix-desktop gives the error
 netflix-desktop : Depends: wine-browser-installer but it is not going to be installed
but dpkg --get-selections | grep hold shows nothing.
I'm running 12.04 64-bit. I've followed the directions in How do I resolve unmet dependencies after adding a PPA?:
  1. Confirmed that main, universe, restricted and multiverse software sources are enabled
  2. sudo apt-get clean
  3. sudo apt-get -f install (returning '0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.')
  4. sudo dpkg --configure -a
  5. sudo apt-get -f install (again '0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.)
  6. sudo apt-get -u dist-upgrade (0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.)
  7. used Y PPA Manager to check for duplicate ppas (none found)
[Edit] I have had the same error with other packages. Here's the output requested by Alaa:
sudo apt-get install wine-browser-installer
Reading package lists... Done
Building dependency tree
 wine-browser-installer : Depends: wine-compholio (>= 1.5.19~precise1)
[Edit 2] doing sudo apt-get install wine-compholio gave a list of further dependencies. I installed each one, and now I have done sudo apt-get install netflix-desktop without error
