When I launch gdb (on Ubuntu 12.04 LTS) it immediately crashes with the following output:
BlockquoteTraceback (most recent call last):
File "/usr/lib/python2.7/site.py", line 562, in <module>
main()
File "/usr/lib/python2.7/site.py", line 544, in main
known_paths = addusersitepackages(known_paths)
File "/usr/lib/python2.7/site.py", line 271, in addusersitepackages
user_site = getusersitepackages()
File "/usr/lib/python2.7/site.py", line 246, in getusersitepackages
user_base = getuserbase() # this will also set USER_BASE
File "/usr/lib/python2.7/site.py", line 236, in getuserbase
USER_BASE = get_config_var('userbase')
File "/usr/lib/python2.7/sysconfig.py", line 577, in get_config_var
return get_config_vars().get(name)
File "/usr/lib/python2.7/sysconfig.py", line 476, in get_config_vars
_init_posix(_CONFIG_VARS)
File "/usr/lib/python2.7/sysconfig.py", line 337, in _init_posix
makefile = _get_makefile_filename()
File "/usr/lib/python2.7/sysconfig.py", line 331, in _get_makefile_filename
return os.path.join(get_path('platstdlib').replace("/usr/local","/usr",1), "config" + (sys.pydebug and "_d" or ""), "Makefile")
AttributeError: 'module' object has no attribute 'pydebug'
From these two similar questions
gdb cannot run due to python error
https://stackoverflow.com/questions/10641201/attributeerror-module-object-has-no-attribute-pydebug
it seems gdb catches the wrong python install?
How do I know which python gdb should use and where do I set which is used?
I have one python in /usr/lib/python2.7 and one in /opt/ros/fuerte/lib/python2.7.
I have previously used gdb successfully on this machine.
Thanks!
