I am trying to run gdb, but as soon as I hit enter I get this error
Traceback (most recent call last):
File "/usr/lib/python2.7/site.py", line 562, in <module>
main()
File "/usr/lib/python2.7/site.py", line 544, in main
known_paths = addusersitepackages(known_paths)
File "/usr/lib/python2.7/site.py", line 271, in addusersitepackages
user_site = getusersitepackages()
File "/usr/lib/python2.7/site.py", line 246, in getusersitepackages
user_base = getuserbase() # this will also set USER_BASE
File "/usr/lib/python2.7/site.py", line 236, in getuserbase
USER_BASE = get_config_var('userbase')
File "/usr/lib/python2.7/sysconfig.py", line 577, in get_config_var
return get_config_vars().get(name)
File "/usr/lib/python2.7/sysconfig.py", line 476, in get_config_vars
_init_posix(_CONFIG_VARS)
File "/usr/lib/python2.7/sysconfig.py", line 337, in _init_posix
makefile = _get_makefile_filename()
File "/usr/lib/python2.7/sysconfig.py", line 331, in _get_makefile_filename
return os.path.join(get_path('platstdlib').replace("/usr/local","/usr",1), "config" + (sys.pydebug and "_d" or ""), "Makefile")
AttributeError: 'module' object has no attribute 'pydebug'
am I missing some package? I have 12.04
Edit:
$ file /usr/bin/gdb
/usr/bin/gdb: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=0x8cd6c593fd6ffe6fd72266bf3d3407ea599b8143, stripped
$ dpkg -S /usr/bin/gdb
gdb: /usr/bin/gdb
