19
In Xubuntu, how do I remove a startup application that was set in Menu –> Setting –> Settings Manager –> Sessions and Startup without using the GUI? My startup command breaks the gui, and I need to disable it using the command line.
Nick
  • 589
Quoting the Xfce Docs ("Some of my applications are always started when I login"):
You can also manually delete those files in ~/Desktop/Autostart and ~/.config/autostart.
For example: open a terminal, type
cd ~/.config/autostart
ls
then rm the files that you want to delete.
ignis
  • 4,247
You can disable autostart entries by hiding them with a higher-precedence entry.
If you don't have it yet, create your own autostart folder:
mkdir -p ~/.config/autostart
and then create .desktop files matching the names of the ones you want to disable from /etc/xdg/autostart (or other sources such as /usr/share/gnome/autostart).
For example, disabling print-applet:
cat > ~/.config/autostart/print-applet.desktop <<EOF
[Desktop Entry]
Type=Application
Hidden=true
EOF
Gabriel
  • 719
for example, to disable AnyDesk from starting up automatically on Ubuntu, you can follow these steps:
Open Terminal: Press Ctrl + Alt + T to open the terminal.
Remove AnyDesk from Autostart: You can remove the AnyDesk entry from the autostart directory. Run the following command to navigate to the autostart directory:
Check for AnyDesk Entry: List the files in the autostart directory to see if there is an entry for AnyDesk:
ls
If you see a file related to AnyDesk, such as anydesk.desktop, proceed to the next step.
Remove AnyDesk Autostart File: Remove the AnyDesk autostart file:
rm anydesk.desktop
Verify AnyDesk Service: To ensure that the AnyDesk service does not start automatically, you can disable the AnyDesk service using systemd. Run the following commands:
sudo systemctl stop anydesk.service
sudo systemctl disable anydesk.service
