Xubuntu remembers things like xfce-terminal and chromium whenever my system starts up. I don't want that function to happen, ever. I want every restart to be fresh. How do I disable this functionality. I've seen numerous tutorials that unchecking the "Save sessions for future logins" screen in Log Off would work, but it does't seem to work for me. When the system comes back the other applications are open.
I've also deleted the files in autostart, as per this question.
Evan Carroll
  • 7,703
Launch xfce4-settings-editor, find and uncheck xfce4-session -> general -> SaveOnExit.
Hope this would help you somewhat
The method I'm telling would not be the best but it would work for you. This will enable the way to start with a new session every time you login. You can also login with default session.
Just follow these steps.
  • Open Session and Startup from Menu - > Settings -> Settings Manager.
  • Untick the Automatically save sessions on logout under Logout Settings
  • Close the Session and Startup window.
  • Logout or restart your system to be sure if you got what you desired.
Another way
If above doesn't work for you then you can start a session every time you login by:
  • Again in Session and Startup Window just tick the option Display chooser in login under Session Chooser
  • Logout and login with a different session by giving a name.
That's all.
Reply if you need further assistance.
Saurav Kumar
  • 15,174
It seems XFCE Sessions occasionally get stuck even if you uncheck Automatically save session on logout.
This may happen after you have it checked (and a session is saved) and you uncheck it. Somehow the last saved session is perpetually restored.
To solve this, after unchecking Automatically save session on logout in Settings Manager > Session and Startup > Saved sessions delete all saved sessions.
This should take care of the stuck session.
brett
  • 182
