I bought a new laptop with Windows 8 pre-installed and I tried to make it dual boot like my windows vista laptop with Ubuntu. Turns out because of some boot sector changes its really complicated now!
Ubuntu installed fine, but it wouldn't boot up windows anymore. After reading a new threads on here about people with the same problem, I Installed and ran the Boot repair software (https://help.ubuntu.com/community/Boot-Repair)
After going through the instructions, I rebooted my computer and it gave me a "Grub Rescue" screen saying
 error: invalid arch independent ELF magic.
 grub rescue>
I am running Ubuntu from the live cd now...and have tried to fix that problem by running
sudo mount /dev/sda1 /mnt
sudo grub-install --root-directory=/mnt /dev/sda
This ended up booting in the "grub" window where it allows me to type some rudimentary commands.
Can anyone help me fix my computer and get back to 1. Ubuntu booting up! 2. Dual boot with my windows which is still installed
Here is the pastebin that Boot-repair gave me to write down after the installation: http://paste.ubuntu.com/5835513
First thing you need to make sure that secure boot is disable in bootloader. After that make changes in boot option and select legacy option. The default one is UEFI. Now insert bootable device whether it's pen drive or cd or DVD. Press F12 and it will show you set of options. Select cd or DVD or pen drive under UEFI mode. Be cautious don't even do mistake in this selection. Don't select it under Legacy option. Ubuntu installation screen will appear within few minutes. Go through it and reach till disk partition page. If this doesn't show you anything don't be panic!! calm down, This means you have to remove dmraid from your installation setup. For that start Ubuntu installation from begining and select "Try Ubuntu" instead of "Install Ubuntu". It will start within few minutes and show you the desktop screen from there select open Terminal. And type. "sudo apt-get remove dmraid" It will remove raid metadata which allows disk to be visible at disk partition page.
Make sure that the partition file system you wish to install Linux, Ubuntu or Backtrack on it is ext4, ext3 or ext2, and not FAT32 or NTFS.
Then mount / on it:
During the installation process press "change" on the partition you wish to use
Make sure "do not use this partition" scroll is not chosen, scroll to ext4, ext3 or ext2
On the "mount" field write /
Click ok, then next a message will appear saying something like "swap area was not defined, do you wish to continue or choose a swap area?", click "ok" and continue or click "go back" and choose another partition and click change, on the file system scroll choose "swap" and click "ok" and next
This will solve both "no root file system is defined" and the "swap area" message, if you still get the swap area message then on step 4 mount /swap to the partition.
At the end select device for boot loader as whole hard disk. e.g. Suppose 500 GB or something.
Create and Keep 100 MB for grub boot something.
Identifying if an Ubuntu has been installed in EFI mode An Ubuntu installed in EFI mode can be detected the following way:
its /etc/fstab file contains an EFI partition (mount point: /boot/efi) it uses the grub-efi bootloader (not grub-pc) from the installed Ubuntu, open a terminal (Ctrl+Alt+T) then type the following command: [ -d /sys/firmware/efi ] && echo "Installed in EFI mode" || echo "Installed in Legacy mode"
Converting Ubuntu into EFI mode Start Boot-Repair, click on "Advanced options", go to the "GRUB location" tab.
If you do not see a "Separate /boot/efi partition" line, this means that your PC does not have any EFI partition. In this case, exit Boot-Repair, then create an EFI partition (see the "Creating an EFI partition" paragraph above). If you see a "Separate /boot/efi partition" line, tick it then click the "Apply" button. Set up your BIOS so that it boots the HDD in EFI mode (see the ""Set up the BIOS in EFI or Legacy mode" paragraph above).
Check that in a set of listed partition you have one windows partition with EFS type and which is basically boot for windows. Keep one thing that you only have one EFS partition in system.
Also follow boot-repair on How do I Dual Boot Windows 8 UEFI and Ubuntu 12.10?
After installation restart system, press F12 and select Ubuntu under EFSI boot option.
Curtesy by:
"No root file system is defined" error during installation
Dual Booting Pre-installed Windows 8
Installing Ubuntu Alongside a Pre-Installed Windows with UEFI
https://help.ubuntu.com/community/UEFI#Setup_the_BIOS_in_EFI_or_Legacy_mode
How can I Install ubuntu on a pc preinstalled with Windows 8?
http://ubuntuforums.org/showthread.php?t=1809562
Jay
