I installed ubuntu/wubi nearly a year ago on my windows 8 pc. It has been sitting on a separate partition untouched since then. I am trying to access it again as I'd like to use Ubuntu now. I cannot figure out how to boot to Ubuntu. When I go to msconfig" -> boot. I only see an option for Windows.
The Ubuntu file hierarchy looks like this:
D:\ -> ubuntu -> disks, install, winboot
The disk file root.disk is about 18gb.
Any help is greatly appreciated.
Alvar
  • 17,038
pandeee
Here's what you can do:
  1. Install Ubuntu via Wubi on your main partition.
  2. Find the Ubuntu install in Program Files or Program Files (x86) on the installation Wubi was installed on before reading this
  3. Copy the root (/) directory and all its contents to your new Wubi install.
  4. Profit!
Alternatively, you can mount the partition with Wubi in it and make a shortcut to its launcher on the old partition.
Dillmo
  • 2,000
You can add an entry to your Windows BCD store so that you get a choice to boot into Ubuntu from the Windows Boot Manager. First open a command prompt as an administrator (right click on CMD.EXE and select Run as administrator).
Then:
bcdedit /create /d Ubuntu /application bootsector
This creates an entry for Ubuntu and returns the {GUID}, but doesn't do anything yet. Note the GUID that is returned and use it in place of xxx-xxx-xxx in the following commands:
bcdedit /set {xxx-xxx-xxx} device partition=D:
bcdedit /set {xxx-xxx-xxx} path \ubuntu\winboot\wubildr.mbr
bcdedit /displayorder {xxx-xxx-xxx} /addlast
bcdedit /timeout 10
After that you will get the option to boot into either Windows or Ubuntu when you boot.
One last thing... make sure there is a C:\wubildr file, or else you will need to copy D:\ubuntu\winboot\wubildr to C:\wubildr
PS... since you are adding this entry manually, it won't be automatically removed by uninstalling Wubi. You can delete it as described here: askubuntu.com/how-do-i-remove-the-extra-ubuntu-option-on-the-windows-boot-manager-menu
bcbc
  • 6,036
