I have Ubuntu 13.10 installed on my computer (D:\ or sda2) via Wubi installer, but recently I have removed my windows and installed windows 8 instead and that removed the option to boot to Ubuntu. I tried to use the boot repair live CD and the grub tool too but it was no good, please I looked for many solution and none of them worked I really need help.
Thanks
There are many utilities you can use with the install media. BCDBOOT or BCDEDIT or mbrfix are just a few examples.
Note that Wubi is considered deprecated ; the official method to install is to use the official iso file.
Also which OS does not boot?
If you want to fix ubuntu then use its live version and in gparted flag ubuntu partition as boot
belacqua
  • 23,540
Windows installer is not compatible with Windows 8 or UEFI firmware, and is not available for Ubuntu 13.10. as stated on official Wubi page.
You can use a general method for dual booting Windows 7/8 and Linux versions on MBR disks.
The method uses a Windows boot sector loader for chain loading grub/grub2.
So you simply add a new boot sector loader to Windows BCD and give it as parameter a file which is a copy of first stage of GRUB2 in this case.
snayob
  • 447
The easiest way to get around this is to insert a bootable disk or usb like you are going to do a fresh install. You'll want to start up to the live desktop, open a terminal, and enter the following:
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install boot-repair
Once it is all done installing, it will launch and you should be able to get it to work with just the recommended repair. If that doesn't want to work for you when you reboot, follow the same steps and then go into the advanced options and you can select the options to reinstall grub, select what OS to boot from, where to place the reinstall of grub, etc.
Note: you have to do this through the ubuntu live desktop from a bootable disk or usb. Do, not reinstall ubuntu or anything like that when you boot into the live session. Just enter that code into the terminal and you should be all good.
