Am i able to install ubuntu first and then install windows? I allocated ubuntu 15gb and im going to load the rest (900gb) for windows but will grub loader work? Or do i have to install windows first and then ubuntu? Thanks
Dan
  • 81
5 Answers5
Though you can technically install Ubuntu and Windows in any order, I would highly recommend that you install Windows first. This is because installing Windows on top of Ubuntu will likely result in messing up the MBR. When that happens, it can be very difficult to boot into Ubuntu, because the Grub dual-boot menu might disappear. It can be a little tricky recovering from that, which you can read all about here:
https://help.ubuntu.com/community/RecoveringUbuntuAfterInstallingWindows
So if you have the opportunity to start from scratch, installing Windows first and Ubuntu second could potentially make your life MUCH easier.
I would most definitely install windows first, and the reason for that is:
  1. This method is recommended by Ubuntu
  2. It takes very little knowledge and all knowledge needed is easily available here: https://help.ubuntu.com/community/WindowsDualBoot
  3. You dont have to think about how much space is required or save any partition space for linux. Simply install windows on all of your available space.
  4. WHEN you start installing Ubuntu simply select "install along side windows", pull the handler to the amount of space you want Ubuntu to have available, and the installer will take care of all the partitioning (Which can be complicated for new users).
  5. Finaly, IF you install windows AFTER you install linux. Windows will delete your boot record, meaning you would have to reinstall it. Thus making things more complicated then it has to be.
Usefull tips: If you have trouble booting into linux after installing. Have a look in your BIOS and look for safeboot and (and i stress and) se if this in anyway prohibits other operating systems (It will say so). If so disable it.
Good luck to you :)
PS: You might want a little more than 15GB... (You might like it :) :)
Izzno
  • 944
  1. Install Ubuntu.
  2. Install Windows.
  3. Update grub boot loader:
    1. Boot Ubuntu from a bootable media like USB/DVD.
    2. Open terminal by pressing Alt+Ctrl+T.
    3. Enter
      1. sudo fdisk -l (to find X and Y)*
      2. sudo mount /dev/sdXY /mnt
      3. sudo grub-install --boot-directory=/mnt/boot /dev/sdX
    4. Boot Ubuntu from disk.
    5. Enter sudo update-grub.
* X is the drive letter and Y is the partition number on which your Ubuntu is installed (for examplesda1).
See https://help.ubuntu.com/community/Grub2/Installing for extra info.
Dante
  • 1,949
Although it is not a Linux-based solution, you can (totally GUI):
  1. Install Ubuntu
  2. Install Windows
  3. Install EasyBCD in Windows and set the boot loader default boot in Ubuntu using Windows environment
  4. (You could skip this and let BCD handle your system's boot, I wouldn't) Reboot in Ubuntu and install Grub in MBR, if not in command line use Grub Customizer.
ps: I suppose you have set some swap space for the Linux install.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
vasilis74
  • 149
They can be installed in either order. The only difference is that installing Windows first will allow the Linux installer to detect it and add an entry for it in the bootloader automatically.
