I want to turn off monitor on a specific period of time automatically (for example between 07:00 and 11:00). Is there any command to be set in crontab file? Is there any better way?
In summary:
Turning off the monitor at 07:00 automatically.
Turning on the monitor at 11:00 automatically.
  • scren-saver & lock screen are disabled!
mini
  • 2,385
Assuming that you are using the default gnome-screensaver for Ubuntu, open a terminal and run next commands followed by instructions:
  1. mkdir -p bin - this command will make a bin directory in your home folder if you don't already have it.
  2. gedit ~/bin/screen_on_or_off.sh - this will create the new file screen_on_or_off.sh in gedit.
  3. Copy and paste the next script:
    #!/bin/bash
    export DISPLAY=:0 #very important if you want to be runned by a cron job
    current_hour=$(date +"%k")
    # Defining the disable_screensaver function
    function disable_screensaver {
        # Disabling sleep time
        # 0 value will never turn the screen off; you can change this value as you wish:
        # for example to turn the screen of after 10 min, use 600
        gsettings set org.gnome.settings-daemon.plugins.power sleep-display-ac 0
        gsettings set org.gnome.settings-daemon.plugins.power sleep-display-battery 0
        gsettings set org.gnome.desktop.session idle-delay 0
    # Defining the enable_screensaver function
    function enable_screensaver {
        # Enabling sleep time to 1 second
        gsettings set org.gnome.settings-daemon.plugins.power sleep-display-ac 1
        gsettings set org.gnome.settings-daemon.plugins.power sleep-display-battery 1
        gsettings set org.gnome.desktop.session idle-delay 1
        notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "Let's go to sleep now!"
    if [ "$current_hour" -ge "7" ] && [ "$current_hour" -lt "11" ]; then
        enable_screensaver
    else
        disable_screensaver
    fi
    exit 0
  4. Save the file and close it.
  5. Go back into terminal and run: chmod +x screen_on_or_off.sh - to grant execute access for the script.
  6. Just for test, to run your new script, type in terminal ~/bin/screen_on_or_off.sh.
  7. Edit the crontab entries using crontab -e command (by default this will edit the current logged-in users crontab) and add the following line:
    */1 * * * * /home/$USER/bin/screen_on_or_off.sh  #change $USER with your username
    I have set the cron job for every minute, but you can change as you wish or as you think is better. See http://en.wikipedia.org/wiki/Cron in this sense.
  8. Save the file and check the new crontab entry with crontab -l.
Now your screen will turn off every day between 7 and 11.
kiri
  • 28,986
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Newer and much simpler answer, put this in cron:
0 07 * * *  export DISPLAY=:0 && xset dpms force off
0 11 * * *  export DISPLAY=:0 && xset dpms force on
