50
I'm testing Natty, and Compiz keeps crashing on me. However, it doesn't always give me the option to restart Compiz, and for some reason doesn't have a fallback window manager(WM) configured.
Without a WM, all my programs are still running, but they're not accepting input from the keyboard, and I can't switch between them.
I can, however, press Ctrl+Alt+F1 and get a terminal, and I can killall Xorg to reset everything; but, I'd rather just reset Compiz, if possible.
If I try typing compiz --replace in the TTY, it complains "fatal--couldn't open display." Is there a way to have TTY1 restart Compiz? Like compiz --replace --display=something?
Additionally, is there a way to configure a fallback window manager so that there's an easier way to recover from Compiz crashing?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Jonathan
  • 7,470
Switch to terminal number 1 (Ctrl+Alt+F1) and run
DISPLAY=:0 unity --replace
or
DISPLAY=:0 compiz --replace
Sometimes it doesn't restart. Just kill all compiz processes and try again in case.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Owais Lone
  • 7,523
13
You need to set the DISPLAY environment variable, in the usual case of a single Xorg instance you can do that with
export DISPLAY=":0.0"
Adam Byrtek
  • 9,861
I had a similar problem with my menubars and taskbar having disappeared.
I tried the above solution but it did not work. However with the following I got my stuff back to normal :)
DISPLAY=:0
compiz --replace
anonymous2
  • 4,325
