12
I've installed Ubuntu and Lubuntu a few times now and some of those times I've had the following problem, which I currently have. When I click a torrent magnet link in Chrome (usually from Pirate bay), instead of opening transmission, the only thing that happens is a new Chrome window opens.
Upon other installations, I've not had this problem; transmission opened just as I'd like.
I've tried using Chrome's extension .torrent to Transmission, but I get the error
unable to contact http ://localhost:9091/transmission/rpc
no response
6 Answers6
13
You can change the default handler for magnet links by editing the file .local/share/applications/mimeapps.list. Add the association to the two sections in the file like this (leaving other entries in those sections intact):
[Default Applications]
x-scheme-handler/magnet=transmission-gtk.desktop
[Added Associations]
Log out and log back in for the change to take effect.
mniess
  • 10,904
If you want to use torrent to transmission, you have to allow remote access in transmission under preferences/remote.
If you want to open magnet links in transmission by clicking on them, you need to patch the /usr/bin/xdg-open script, here's mine for reference. The added lines are 311 and 490-493.
tpv
  • 366
If you have installed transmission-gtk then the solution is easy.
gconftool-2 -s /desktop/gnome/url-handlers/magnet/command '/usr/bin/transmission-gtk %s' --type String
gconftool-2 -s /desktop/gnome/url-handlers/magnet/enabled --type Boolean true
The first one adds transmission-gtk as handler for magnet:// links the second enable it.
Since chrome/ium uses xdg-open this is the best method for setting the handlers. You can replace /usr/bin/transmission-gtk for any client you like. This works for almost all flavors of Ubuntu.
You can test this issuing in the terminal xdg-open "magnet:?xt=urn:btih:f41989f9797a88505f9e258d5e5d1354c3731a99" (downloads Ubuntu 13.04 64-bit)
Other solution is using xdg-mime:
xdg-mime default transmission-gtk.desktop application/x-bittorrent
xdg-mime default transmission-gtk.desktop x-scheme-handler/magnet
In case you don't have the mime-types installed use xdg-mime install x-scheme-handler/magnet.
Braiam
  • 69,112
no response
To fix this
  1. Install transmission-remote
    sudo apt-get install transmission-remote
  2. Start transmission (transmission-gtk) before adding .torrent files
  3. Enable web client, set port to 9091 (From edit -> preference -> web ) if necessary
totti
  • 6,908
  • 40
  • 48
if ur using bittorrent go to preferences-general-click on the tab that says associate with torrents..now it will work when you try magnet link..
If you want to Open Piratebay magnet link with Transmission Client then on Magnet Link 1 Right Click 2 Copy Link Location Open Transmission File> Open URL
It's Done
Manish
