After the recent updates I've installed I got the following error when installing or uninstalling apps from Ubuntu Software center on Ubuntu 13.04:
installArchives() failed: (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 332535 files and directories currently installed.)
Removing gelemental ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for menu ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for man-db ...
Setting up linux-image-extra-3.8.0-25-generic (3.8.0-25.37) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.8.0-25-generic /boot/vmlinuz-3.8.0-25-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.8.0-25-generic /boot/vmlinuz-3.8.0-25-generic
update-initramfs: Generating /boot/initrd.img-3.8.0-25-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.8.0-25-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-extra-3.8.0-25-generic.postinst line 1010.
dpkg: error processing linux-image-extra-3.8.0-25-generic (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-extra-3.8.0-25-generic; however:
Package linux-image-extra-3.8.0-25-generic is not configured yet.
dpkg: error processing linux-image-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.8.0.25.43); however:
Package linux-image-generic is not configured yet.
dpkg: error processing linux-generic (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
linux-image-generic
linux-generic
Error in function:
Running depmod.
cpio: write error: Broken pipe
E: mkinitramfs failure cpio 1 gzip 1
It says there is not space left on the device, but I actually have plenty of space, the only partition that has 24 MB free is the boot partition, but how to access is it and what to do there if this is the problem?
Braiam
  • 69,112
Disclaimer: this answer contains information from a comment to another answer.
It was also failing for me to install the latest kernel via Muon Package Manager. Then i did:
vic@vic-X202E ~ $ sudo apt-get install -f
[sudo] password for vic:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libkdcraw22 linux-headers-3.8.0-19 linux-headers-3.8.0-19-generic linux-headers-3.8.0-21
  linux-headers-3.8.0-21-generic linux-image-3.8.0-19-generic linux-image-3.8.0-21-generic
  linux-image-extra-3.8.0-19-generic linux-image-extra-3.8.0-21-generic
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-3.8.0-27-generic (3.8.0-27.40) ...
Running depmod.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.8.0-27-generic /boot/vmlinuz-3.8.0-27-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.8.0-27-generic /boot/vmlinuz-3.8.0-27-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.8.0-27-generic /boot/vmlinuz-3.8.0-27-generic
update-initramfs: Generating /boot/initrd.img-3.8.0-27-generic
update-initramfs: failed for /boot/initrd.img-3.8.0-27-generic with 1.
I did sudo apt-get autoremove which removed old kernels for me, after that the new kernel could be installed.
I guess, the boot partition which has no more space left is the Efi partition.
warvariuc
  • 2,335
What worked for me is:
sudo apt-get install plymouth
Oleg
  • 143
you need to reconfigure the kernel package
sudo dpkg-reconfigure linux-image-extra-3.8.0-25-generic
or try fix the depencies by
herrhansen
  • 251
