I cannot do any apt-get commands without error. I have tried many commands like sudo apt-get purge, sudo apt-get -f install, sudo dpkg --configure initramfs-tools, etc.
I continue to get the following:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up linux-image-extra-3.19.0-23-generic (3.19.0-23.24) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.19.0-23-generic /boot/vmlinuz-3.19.0-23-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.19.0-23-generic /boot/vmlinuz-3.19.0-23-generic
update-initramfs: Generating /boot/initrd.img-3.19.0-23-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.19.0-23-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-extra-3.19.0-23-generic (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-extra-3.19.0-23-generic; however:
Package linux-image-extra-3.19.0-23-generic is not configured yet.
dpkg: error processing package linux-image-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.19.0.23.22); however:
Package linux-image-generic is not configured yet.
dpkg: error processing package linux-generic (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
linux-image-generic
linux-generic
scott@scott-1015E:/$
Can anyone help me?
