19
Does TLP automatically start when my system boots? Everytime i boot into Ubuntu i open a terminal and type sudo tlp startonly then i can find the difference in the system temperature. If TLP doesnt start automatically, Is there a way to add it as a startup applications?
and everytime the power mode changes from ac to battery or vice versa i need to again type
sudo tlp start. Is there a way TLP can switch modes automatically?
As mentioned in this link i did type systemctl enable tlp but i get an error :
systemctl: command not found. So what do i do now?
user167377
  • 191
Yes TLP will automatically start you do not need to run any command
please check
  0.) General
  TLP_ENABLE=1
Set to 0 to disable TLP (Reboot needed), It should be enabled so leave the default value
Is there a power saving application similar to Jupiter?
If you're not sure you can always check whether TLP is running by typing in a terminal:
sudo tlp-stat -s
guntbert
  • 13,475
Qasim
  • 22,162
TLP is exepcted to start automatically on every boot once you run the command :
sudo tlp-start
However that might not work everytime. So you should instead try running :
sudo tlp-stat -s
if you get the following output : like this
then try running:
systemctl enable tlp.service
this should work for you.
Open termainal and type:
sudo systemctl enable tlp.service
press enter. Type password and press enter. TLP should now start at boot.
