I'm trying to istall AMD/Intel hybrid drivers using this guide and have problem with lib32gcc1 when I'm try to install fglrx*.deb's sudo dpkg -i fglrx*.deb. I get dependency problems with it:
 dpkg: dependency problems prevent configuration of fglrx:
 fglrx depends on lib32gcc1; however:
  Package lib32gcc1 is not installed.
 fglrx depends on libc6-i386; however:
  Package libc6-i386 is not installed.
It says "Package lib32gcc1 is not installed." but look:
sudo apt-cache search lib32gcc1
lib32gcc1 - GCC support library (32 bit Version)
lib32gcc1-dbg - GCC support library (debug symbols)
then I'm tried:
sudo apt-get install lib32gcc1
Reading package lists... Done
Building dependency tree
 lib32gcc1 : Depends: libc6-i386 (>= 2.2.4) but it is not going to be installed
also
sudo apt-get -f install
don't help.
What is the problem? Is lib32gcc1 exists or not? If it don't exists how can I get it to provide installation of fglrx*.deb's?
yujaiyu
  • 214
A few things to try:
  1. Run dpkg --print-architecture and see what it outputs. On a 64-bit Intel/AMD system, this should print amd64.
  2. Run dpkg --print-foreign-architectures and see what it outputs. It should print i386
  3. If you doesn't print i386 for the previous step, run sudo dpkg --add-architecture i386 which should allow you to install 32-bit versions of things like libc6-i386
Powerlord
  • 536
I solved problem with installing Catalyst driver using this tutorial. It seems like correct way to install all dependencies including lib32gcc1 is:
sudo apt-get install build-essential cdbs dh-make dkms execstack dh-modaliases linux-headers-generic fakeroot libqtgui4 lib32gcc1
yujaiyu
  • 214
