How do i update only pidgin using apt-get?
I tried
> sudo apt-get update pidgin
but i get
> The update command takes no arguments
I tried
but i get
To update Pidgin to 2.10.7, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo add-apt-repository ppa:pidgin-developers/ppa
sudo apt-get update
sudo apt-get install pidgin
Thanks to this answer by Peachy
sudo apt-get --only-upgrade install pidgin
As man apt-get describes it, apt-get update will resynchronize the package index files from their sources while apt-get upgrade will install the newest versions of all packages currently installed on the system from the sources enumerated in your package list aforementioned.
As described in other answers, if you want a newest version than the one in standard packages of your distribution, you have to either edit your sources lists, add a new PPA, install from more recent binaries or compile from source.
