30
According to the jekyll site, this is how you make a new website with jekyll:
~ $ gem install jekyll
~ $ jekyll new myblog
~ $ cd myblog
~/myblog $ jekyll serve
gem install jekyll didn't work, nor did sudo gem install jekyll:
└─>gem install jekyll
ERROR:  While executing gem ... (Errno::EACCES)
    Permission denied - /var/lib/gems/1.9.1/gems/fast-stemmer-1.0.2/LICENSE
┌─[Sat Jun 08][jon@jon-MacMini:~/Web]
└─>sudo !!
Building native extensions.  This could take a while...
ERROR:  Error installing jekyll:
    ERROR: Failed to build gem native extension.
        /usr/bin/ruby1.9.1 extconf.rb
/usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require': cannot load such file -- mkmf (LoadError)
    from /usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require'
    from extconf.rb:1:in `<main>'
Gem files will remain installed in /var/lib/gems/1.9.1/gems/fast-stemmer-1.0.2 for inspection.
Results logged to /var/lib/gems/1.9.1/gems/fast-stemmer-1.0.2/ext/gem_make.out
I also tried following the answer here, but that doesn't help. sudo apt-get install jekyll works. Even then, though, running jekyll new myblog returns this error:
└─>jekyll new myblog
/usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require': iconv will be deprecated in the future, use String#encode instead.
WARNING: Could not read configuration. Using defaults (and options).
    No such file or directory - new/_config.yml
Building site: new -> myblog
/usr/lib/ruby/vendor_ruby/jekyll/site.rb:126:in `chdir': No such file or directory - /home/jon/Web/new/ (Errno::ENOENT)
    from /usr/lib/ruby/vendor_ruby/jekyll/site.rb:126:in `read_directories'
    from /usr/lib/ruby/vendor_ruby/jekyll/site.rb:98:in `read'
    from /usr/lib/ruby/vendor_ruby/jekyll/site.rb:38:in `process'
    from /usr/bin/jekyll:250:in `<main>'
Anyone know what's causing this?
Jonathan
  • 7,470
On my 13.04 and 14.04 systems, things worked for me after installing the ruby-dev package, then running the gem install:
  • sudo apt-get install ruby1.9.1-dev (or try: ruby-dev instead)
  • gem install jekyll # if this fails then sudo gem install jekyll
After that, jekyll was installed correctly.
Note that for the gem install instruction, it is better not to use sudo.*****
It's better to use something like RVM, so that sudo isn't required. On some systems it may be necessary to use sudo, if for instance permissions were set by previous sudo commands or root-level configuration.
See this stackoverflow question -- how to install gems without sudo for more information and for help on getting permissions set to user instead of root.
***** Credit to @iguarav for this best practices advice as well as the link to rvm.io.
belacqua
  • 23,540
Guide for 14.04 LTS without RVM
Jekyll 3 needs ruby 2.0 or higher, so we first install ruby 2.0, it's development headers and nodejs:
sudo apt-get install -y ruby2.0 ruby2.0-dev nodejs
Then we point the commands included in the ruby package to the new version.
sudo update-alternatives --install /usr/bin/ruby ruby /usr/bin/ruby2.0 10
sudo update-alternatives --install /usr/bin/gem gem /usr/bin/gem2.0 10
sudo update-alternatives --install /usr/bin/irb irb /usr/bin/irb2.0 10
sudo update-alternatives --install /usr/bin/rdoc rdoc /usr/bin/rdoc2.0 10
sudo update-alternatives --install /usr/bin/testrb testrb /usr/bin/testrb2.0 10
sudo update-alternatives --install /usr/bin/rake rake /usr/bin/rake2.0 10
sudo update-alternatives --install /usr/bin/erb erb /usr/bin/erb2.0 10
sudo update-alternatives --install /usr/bin/ri ri /usr/bin/ri2.0 10
And finally we use gem to install the jekyll gem.
mschwaig
  • 131
Also, you don't want to depend on sudo for executing gems, so I recommend to add your user to the root's group and:
sudo chmod -R 770 /var/lib/gems
sudo chmod -R 770 /usr/local/bin
Just doing a few updates on this thread. According the jekyll's installation docs the version needed is version 2. After fixing the permissions issue, I ran into that expected error:
jekyll requires Ruby version >= 2.0.0.
Installing with RVM:
gpg --keyserver hkp://keys.gnupg.net --recv-keys \  409B6B1796C275462A1703113804BB82D39DC0E3
curl -sSL https://get.rvm.io | bash -s stable --ruby
/bin/bash --login
rvm install 2.3.0
rvm use 2.3.0
rvm rubygems latest
ruby --version
rvm install ruby-dev
For other issues with the Ruby installation, follow this.
After that, it worked for me.
3manuek
  • 113
