I'm using Ubuntu 12.04.
I am trying to install Jekyll through gem with
sudo gem install jekyll
but I get this error at some point of the installation:
ERROR:  While generating documentation for jekyll-0.12.1
... MESSAGE:   Unhandled special: Special: type=17, text="<!-- more -->"
... RDOC args: --ri --op /usr/lib/ruby/gems/1.8/doc/jekyll-0.12.1/ri --charset=UTF-8 lib README.textile LICENSE --title jekyll-0.12.1 Documentation --quiet
techraf
  • 3,316
sudo gem install rdoc
Then
you can see the answer at https://github.com/mojombo/jekyll/issues/762
Eric Carvalho
  • 55,453
dongsir
  • 76
I'll brave enough to post another answer. I've just installed Jekyll on Ubuntu 12.04, so I hope that this piece of text will save somebody's time.
Firstly, you'll have problems with ruby-1.8.
You should install ruby-1.9 as described here:
sudo apt-get update
sudo apt-get install ruby1.9.1 ruby1.9.1-dev rubygems1.9.1 irb1.9.1 ri1.9.1 rdoc1.9.1 build-essential libopenssl-ruby1.9.1 libssl-dev zlib1g-dev
sudo update-alternatives --install /usr/bin/ruby ruby /usr/bin/ruby1.9.1 400 \
        --slave   /usr/share/man/man1/ruby.1.gz ruby.1.gz \
                        /usr/share/man/man1/ruby1.9.1.1.gz \
        --slave   /usr/bin/ri ri /usr/bin/ri1.9.1 \
        --slave   /usr/bin/irb irb /usr/bin/irb1.9.1 \
        --slave   /usr/bin/rdoc rdoc /usr/bin/rdoc1.9.1
choose your interpreter changes symlinks for /usr/bin/ruby, /usr/bin/gem, /usr/bin/irb, /usr/bin/ri and man (1) ruby
sudo update-alternatives --config ruby
sudo update-alternatives --config gem
now try
ruby --version
Unfortunately, this is not enough. May be some commands here are odd and you can install jekyll without them... But let them be. Maybe somebody will improve my answer.
As of 2016-11-26, jekyll and rdoc required ruby-2.2. Install it as described:
sudo apt-add-repository ppa:brightbox/ruby-ng
sudo apt-get update
sudo apt-get install ruby2.2 ruby2.2-dev
ruby2.2 -v
Then install rdoc and jekyll:
sudo gem install rdoc jekyll
Update alternatives again:
Of course, you should choose *2.2
Finally, now you can install jekyll:
NickKolok
  • 119
