I used gnome-shell for a while and I became addicted to the possibility to add workspaces simply moving a window in the last one on bottom; and obviously to remove all remaining empty workspace except the last, used as a trigger for new ones. I do not know if I explained well.
Is there any extension/configuration to add this feature to Unity?
EDIT: to avoid confusion I post a video that shows how workspaces are added and removed automatically by gnome-shell
Thanks
gc5
  • 1,141
@Francesco It should be on by default if you are using 12.04 or 12.10. If you are using 13.04 it is still installed just off by default. To turn it back on just go to Settings->Appearance->Behavior and check the Enable Workspaces box
G.Oxsen
  • 234
I followed what was suggested here. However, instead of using gconftool, we should be using dconf. An example is dconf write /org/compiz/profiles/unity/plugins/core/vsize 2 to have 2 rows in the workspace grid.
