This morning, I removed all the unity-webapps-something and didn't pay attention that removing unity-webapps-service or unity-webappas-common required to remove other key packages:
The following packages will be REMOVED:
  bamfdaemon hud indicator-appmenu indicator-sound libbamf3-1 libunity-webapps0 lightdm-remote-session-uccsconfigure unity unity-tweak-tool unity-webapps-common
  unity-webapps-service xul-ext-unity xul-ext-websites-integration
0 upgraded, 0 newly installed, 13 to remove and 1 not upgraded.
After this operation, 10.3 MB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 458920 files and directories currently installed.)
Removing unity-tweak-tool ...
Removing lightdm-remote-session-uccsconfigure ...
Removing unity ...
Removing indicator-sound ...
Removing indicator-appmenu ...
Removing hud ...
Removing libbamf3-1:amd64 ...
Removing bamfdaemon ...
Removing xul-ext-unity ...
Removing xul-ext-websites-integration ...
Removing unity-webapps-common ...
Removing libunity-webapps0 ...
Removing unity-webapps-service ...
Now, that I login to my unity session, I have no launcher, no top panel, global menu integration and hud are disabled.
  • I reinstalled all the packages removed above and restarted the computer but in vain.
  • I reconfigured these packages but in vain (sudo dpkg-reconfigure unity)
  • I issued: unity --replace and compiz --replace but in vain.
Any Ideas please. this is kind of frustrating.
PS: At the greeter stage, everything is fine. It's only when I log in. I can also login to my gnome Fall back session without problems.
Hanynowsky
  • 2,801
SOrry! Just got the answer here: Unity doesn't load, no Launcher, no Dash appears
Since Unity package was removed, the unity plugin in Compiz manager got disabled. So opening compiz manager and re-enabling the plugin did the trick.
Hanynowsky
  • 2,801
