36
How can I fix the following error with sudo?
/etc$ sudo
sudo: /etc/sudoers.d is world writable
usage: sudo [-D level] -h | -K | -k | -V
usage: sudo -v [-AknS] [-D level] [-g groupname|#gid] [-p prompt] [-u user
            name|#uid]
usage: sudo -l[l] [-AknS] [-D level] [-g groupname|#gid] [-p prompt] [-U user
            name] [-u user name|#uid] [-g groupname|#gid] [command]
usage: sudo [-AbEHknPS] [-r role] [-t type] [-C fd] [-D level] [-g
            groupname|#gid] [-p prompt] [-u user name|#uid] [-g groupname|#gid]
            [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-r role] [-t type] [-C fd] [-D level] [-g
            groupname|#gid] [-p prompt] [-u user name|#uid] file ...
demure
  • 2,322
kismat
  • 361
Run pkexec chmod 0755 /etc/sudoers.d
pkexec will use a different method of using root permissions, bypassing the issue.
And the chmod will fix the permissions.
kos
  • 41,268
demure
  • 2,322
40
Run this 2 commands with (555) permissions:
pkexec chmod 555 /etc/sudoers
pkexec chmod 555 /etc/sudoers.d/README
edwinksl
  • 24,109
12
Did you try going into recovery mode and switching the permissions back to 775 for sudoers? I tried it and it worked.
1) Get into Ubuntu Recovery
2) Do mount -rw -o remount /
3) Then chmod 775 -R /etc/sudoers and chmod 775 -R /etc/sudoers.d/.
This time it should work.
4) Then do a sudo apt-get install of any package to test before you leave recovery mode. Late reply but I encountered the issue recently and tried this. It worked fine atleast for the world writable issue.
Gdcrocx
  • 121
