I can't remember what command I ran that did this but I can't seem to do anything because of this error. Is there way to reverse it?enter image description here
Asked
Active
Viewed 98 times
What I can understand from the image you have attached is that:
- Your sudoers file's permissions are not correct.
To fix that you can try the following:
su root # login to root, if you are not already logged in as root
chmod 644 /usr/lib/sudo/sudoers.so # this make it only writable by the owner
chown -R root /usr/lib/sudo # to set the owner as root
In case if you're having trouble with su root try
pkexec su
I'm a new contributor, so I'm sorry if my answers are not good enough.
ChilledGamer
- 101
- 2
