Recently I have been noticing that my laptop's speed has decreased after installing Ubuntu. I am on a MacBook Pro and I have 4.2GHz and 4GB of RAM. I used to play games like Minecraft before on it and they ran fine with 60 FPS. But now that I am in Ubuntu, things don't go as fast as they used to.
I made Minecraft run with 3GB of RAM and I installed Optifine, but it is still slow! I don't know what to do anymore!
Seth
  • 59,332
For a bit more info, open a terminal and type 'top'. It will show you what's running and what's at the top is likely your problem.
Marc
  • 10,152
Try installing cpu indicator it allows you to change the speed of your CPU
sudo apt-get install indicator-cpufreq
Then logout and login again and you will see a little cpu indicator in your notification panel. Set it to "Permormance" and that should boost the speed.
Meer Borg
  • 5,003
