Introduction
Recently I upgraded to the Ubuntu 24.04.1 LTS. Since then my computer seems to have slowed down. Even when I type into the keyboard I notice it is slowed down. However, it might be a conincidence. Perhaps my computer was slowing down before I upgraded to Ubuntu 24.04.1 LTS. All I know is that I am getting frustrated and losing productivity. I looked at a few similar questoins and tried to make heads or tails of my situtation. I need some help.
The questions, answers, and comments in [1] are relevant to my problem. I typed top and see that gnome-shell is using 25-40% of my CPU. Firefox (when minimal tabs open) is eating 5-7%. Firefox when I have videopages (i.e., things like netflix) is eating 30% or more of the CPU. When I compile *.tex files with Texmaker 100% of my CPU is used.
The questions, answers, and comments in [2] relevant to my problem.
(A) I tried looking at my hard drive using sudo smartctl -t long /dev/nvme0n1. What I got was
Read Self-test Log failed: Invalid Field in Command (0x4002)
(B) I typed sudo fdisk -l. What I got was:
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 55.66 MiB, 58363904 bytes, 113992 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop2: 55.36 MiB, 58052608 bytes, 113384 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop3: 63.97 MiB, 67080192 bytes, 131016 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop4: 74.25 MiB, 77852672 bytes, 152056 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop5: 63.7 MiB, 66789376 bytes, 130448 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop6: 73.88 MiB, 77463552 bytes, 151296 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop7: 273.61 MiB, 286900224 bytes, 560352 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/nvme0n1: 238.47 GiB, 256060514304 bytes, 500118192 sectors Disk model: WDC PC SN730 SDBQNTY-256G-1001
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 16A7BEFD-1231-4939-803B-7DB462F6426F
Device Start End Sectors Size Type /dev/nvme0n1p1 2048 23437311 23435264 11.2G Linux swap /dev/nvme0n1p2 23437312 218748927 195311616 93.1G Linux filesystem /dev/nvme0n1p3 218748928 220702719 1953792 954M EFI System /dev/nvme0n1p4 220702720 500117503 279414784 133.2G Linux filesystem
Disk /dev/loop8: 272.98 MiB, 286236672 bytes, 559056 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop9: 11.11 MiB, 11649024 bytes, 22752 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop10: 164.82 MiB, 172830720 bytes, 337560 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop11: 504.15 MiB, 528642048 bytes, 1032504 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop12: 505.09 MiB, 529625088 bytes, 1034424 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop13: 164.82 MiB, 172830720 bytes, 337560 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop14: 91.69 MiB, 96141312 bytes, 187776 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop15: 12.2 MiB, 12791808 bytes, 24984 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop16: 10.67 MiB, 11186176 bytes, 21848 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop17: 38.83 MiB, 40714240 bytes, 79520 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop18: 44.14 MiB, 46280704 bytes, 90392 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop19: 564 KiB, 577536 bytes, 1128 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop20: 321.08 MiB, 336678912 bytes, 657576 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop21: 568 KiB, 581632 bytes, 1136 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop22: 321.1 MiB, 336699392 bytes, 657616 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
(C) grep -i sda /var/log/syslog* . A small portion of what I got (so much came out that I exceeded stackechange boy limit of 30000 characters) was:
 /var/log/syslog.1:2024-11-18T17:56:10.395808-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Housekeeping.target - GNOME maintenance of expirable data target.
/var/log/syslog.1:2024-11-18T17:56:10.396343-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Keyboard.target - GNOME keyboard configuration target.
/var/log/syslog.1:2024-11-18T17:56:10.396710-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.MediaKeys.target - GNOME keyboard shortcuts target.
/var/log/syslog.1:2024-11-18T17:56:10.397096-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Power.target - GNOME power management target.
/var/log/syslog.1:2024-11-18T17:56:10.397421-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.PrintNotifications.target - GNOME printer notifications target.
/var/log/syslog.1:2024-11-18T17:56:10.397686-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Rfkill.target - GNOME RFKill support target.
/var/log/syslog.1:2024-11-18T17:56:10.398376-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.ScreensaverProxy.target - GNOME FreeDesktop screensaver target.
/var/log/syslog.1:2024-11-18T17:56:10.401417-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Sharing.target - GNOME file sharing target.
/var/log/syslog.1:2024-11-18T17:56:10.401781-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Smartcard.target - GNOME smartcard target.
/var/log/syslog.1:2024-11-18T17:56:10.402106-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Sound.target - GNOME sound sample caching target.
/var/log/syslog.1:2024-11-18T17:56:10.402340-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.Wacom.target - GNOME Wacom tablet support target.
/var/log/syslog.1:2024-11-18T17:56:10.402582-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped target org.gnome.SettingsDaemon.XSettings.target - GNOME XSettings target.
/var/log/syslog.1:2024-11-18T17:56:10.416611-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopping org.gnome.SettingsDaemon.Color.service - GNOME color management service...
/var/log/syslog.1:2024-11-18T17:56:10.417706-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopping org.gnome.SettingsDaemon.Keyboard.service - GNOME keyboard configuration service...
/var/log/syslog.1:2024-11-18T17:56:10.418245-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopping org.gnome.SettingsDaemon.MediaKeys.service - GNOME keyboard shortcuts service...
/var/log/syslog.1:2024-11-18T17:56:10.420038-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopping org.gnome.SettingsDaemon.Power.service - GNOME power management service...
/var/log/syslog.1:2024-11-18T17:56:10.420530-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopping org.gnome.SettingsDaemon.Wacom.service - GNOME Wacom tablet support service...
/var/log/syslog.1:2024-11-18T17:56:10.426760-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: Stopped org.gnome.SettingsDaemon.XSettings.service - GNOME XSettings service.
/var/log/syslog.1:2024-11-18T17:56:10.427295-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[1963]: org.gnome.SettingsDaemon.XSettings.service: Consumed 7.619s CPU time.
/var/log/syslog.1:2024-11-18T18:14:10.965486-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Dependency failed for org.gnome.SettingsDaemon.XSettings.service - GNOME XSettings service.
/var/log/syslog.1:2024-11-18T18:14:10.965664-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: org.gnome.SettingsDaemon.XSettings.service: Job org.gnome.SettingsDaemon.XSettings.service/start failed with result 'dependency'.
/var/log/syslog.1:2024-11-18T18:14:10.966240-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.XSettings.target - GNOME XSettings target.
/var/log/syslog.1:2024-11-18T18:14:10.987233-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.A11ySettings.service - GNOME accessibility service...
/var/log/syslog.1:2024-11-18T18:14:10.997128-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Color.service - GNOME color management service...
/var/log/syslog.1:2024-11-18T18:14:11.009891-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Datetime.service - GNOME date & time service...
/var/log/syslog.1:2024-11-18T18:14:11.018616-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Housekeeping.service - GNOME maintenance of expirable data service...
/var/log/syslog.1:2024-11-18T18:14:11.022503-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Keyboard.service - GNOME keyboard configuration service...
/var/log/syslog.1:2024-11-18T18:14:11.030533-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.MediaKeys.service - GNOME keyboard shortcuts service...
/var/log/syslog.1:2024-11-18T18:14:11.045860-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Power.service - GNOME power management service...
/var/log/syslog.1:2024-11-18T18:14:11.060985-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.PrintNotifications.service - GNOME printer notifications service...
/var/log/syslog.1:2024-11-18T18:14:11.061815-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Rfkill.service - GNOME RFKill support service...
/var/log/syslog.1:2024-11-18T18:14:11.067266-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.ScreensaverProxy.service - GNOME FreeDesktop screensaver service...
/var/log/syslog.1:2024-11-18T18:14:11.078058-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Sharing.service - GNOME file sharing service...
/var/log/syslog.1:2024-11-18T18:14:11.090008-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Smartcard.service - GNOME smartcard service...
/var/log/syslog.1:2024-11-18T18:14:11.107623-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Sound.service - GNOME sound sample caching service...
/var/log/syslog.1:2024-11-18T18:14:11.116895-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.Wacom.service - GNOME Wacom tablet support service...
/var/log/syslog.1:2024-11-18T18:14:11.120975-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.A11ySettings.service - GNOME accessibility service.
/var/log/syslog.1:2024-11-18T18:14:11.148467-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.A11ySettings.target - GNOME accessibility target.
/var/log/syslog.1:2024-11-18T18:14:11.438181-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Smartcard.service - GNOME smartcard service.
/var/log/syslog.1:2024-11-18T18:14:11.438654-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Datetime.service - GNOME date & time service.
/var/log/syslog.1:2024-11-18T18:14:11.439026-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Housekeeping.service - GNOME maintenance of expirable data service.
/var/log/syslog.1:2024-11-18T18:14:11.458726-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started app-gnome-org.gnome.SettingsDaemon.DiskUtilityNotify-3119.scope - Application launched by gnome-session-binary.
/var/log/syslog.1:2024-11-18T18:14:11.462759-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Datetime.target - GNOME date & time target.
/var/log/syslog.1:2024-11-18T18:14:11.463094-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Housekeeping.target - GNOME maintenance of expirable data target.
/var/log/syslog.1:2024-11-18T18:14:11.463407-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Smartcard.target - GNOME smartcard target.
/var/log/syslog.1:2024-11-18T18:14:11.495528-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.ScreensaverProxy.service - GNOME FreeDesktop screensaver service.
/var/log/syslog.1:2024-11-18T18:14:11.496135-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Sharing.service - GNOME file sharing service.
/var/log/syslog.1:2024-11-18T18:14:11.496943-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.ScreensaverProxy.target - GNOME FreeDesktop screensaver target.
/var/log/syslog.1:2024-11-18T18:14:11.497248-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Sharing.target - GNOME file sharing target.
/var/log/syslog.1:2024-11-18T18:14:11.505891-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.PrintNotifications.service - GNOME printer notifications service.
/var/log/syslog.1:2024-11-18T18:14:11.506687-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.PrintNotifications.target - GNOME printer notifications target.
/var/log/syslog.1:2024-11-18T18:14:11.574474-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Sound.service - GNOME sound sample caching service.
/var/log/syslog.1:2024-11-18T18:14:11.574798-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Sound.target - GNOME sound sample caching target.
/var/log/syslog.1:2024-11-18T18:14:11.768442-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Rfkill.service - GNOME RFKill support service.
/var/log/syslog.1:2024-11-18T18:14:11.768683-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Rfkill.target - GNOME RFKill support target.
/var/log/syslog.1:2024-11-18T18:14:14.131565-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Color.service - GNOME color management service.
/var/log/syslog.1:2024-11-18T18:14:14.131939-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Color.target - GNOME color management target.
/var/log/syslog.1:2024-11-18T18:14:14.136367-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Keyboard.service - GNOME keyboard configuration service.
/var/log/syslog.1:2024-11-18T18:14:14.136959-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Keyboard.target - GNOME keyboard configuration target.
/var/log/syslog.1:2024-11-18T18:14:14.218591-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Wacom.service - GNOME Wacom tablet support service.
/var/log/syslog.1:2024-11-18T18:14:14.220002-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Wacom.target - GNOME Wacom tablet support target.
/var/log/syslog.1:2024-11-18T18:14:14.227331-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.MediaKeys.service - GNOME keyboard shortcuts service.
/var/log/syslog.1:2024-11-18T18:14:14.227659-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.MediaKeys.target - GNOME keyboard shortcuts target.
/var/log/syslog.1:2024-11-18T18:14:14.259896-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.Power.service - GNOME power management service.
/var/log/syslog.1:2024-11-18T18:14:14.260214-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Reached target org.gnome.SettingsDaemon.Power.target - GNOME power management target.
/var/log/syslog.1:2024-11-18T19:04:00.908487-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Starting org.gnome.SettingsDaemon.XSettings.service - GNOME XSettings service...
/var/log/syslog.1:2024-11-18T19:04:01.442827-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: Started org.gnome.SettingsDaemon.XSettings.service - GNOME XSettings service.
/var/log/syslog.1:2024-11-19T20:01:06.803279-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: org.gnome.SettingsDaemon.Housekeeping.service: Consumed 4.074s CPU time.
/var/log/syslog.1:2024-11-19T20:01:06.844468-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2577]: org.gnome.SettingsDaemon.Sharing.service: Consumed 5.002s CPU time.
/var/log/syslog.1:2024-11-19T20:02:01.994346-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Dependency failed for org.gnome.SettingsDaemon.XSettings.service - GNOME XSettings service.
/var/log/syslog.1:2024-11-19T20:02:01.994562-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: org.gnome.SettingsDaemon.XSettings.service: Job org.gnome.SettingsDaemon.XSettings.service/start failed with result 'dependency'.
/var/log/syslog.1:2024-11-19T20:02:01.995076-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.XSettings.target - GNOME XSettings target.
/var/log/syslog.1:2024-11-19T20:02:02.024604-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.A11ySettings.service - GNOME accessibility service...
/var/log/syslog.1:2024-11-19T20:02:02.028910-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Color.service - GNOME color management service...
/var/log/syslog.1:2024-11-19T20:02:02.039312-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Datetime.service - GNOME date & time service...
/var/log/syslog.1:2024-11-19T20:02:02.044635-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Housekeeping.service - GNOME maintenance of expirable data service...
/var/log/syslog.1:2024-11-19T20:02:02.068675-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Keyboard.service - GNOME keyboard configuration service...
/var/log/syslog.1:2024-11-19T20:02:02.077337-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.MediaKeys.service - GNOME keyboard shortcuts service...
/var/log/syslog.1:2024-11-19T20:02:02.082232-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Power.service - GNOME power management service...
/var/log/syslog.1:2024-11-19T20:02:02.092620-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.PrintNotifications.service - GNOME printer notifications service...
/var/log/syslog.1:2024-11-19T20:02:02.097371-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Rfkill.service - GNOME RFKill support service...
/var/log/syslog.1:2024-11-19T20:02:02.104346-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.ScreensaverProxy.service - GNOME FreeDesktop screensaver service...
/var/log/syslog.1:2024-11-19T20:02:02.111559-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Sharing.service - GNOME file sharing service...
/var/log/syslog.1:2024-11-19T20:02:02.116673-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Smartcard.service - GNOME smartcard service...
/var/log/syslog.1:2024-11-19T20:02:02.124778-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Sound.service - GNOME sound sample caching service...
/var/log/syslog.1:2024-11-19T20:02:02.129163-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Starting org.gnome.SettingsDaemon.Wacom.service - GNOME Wacom tablet support service...
/var/log/syslog.1:2024-11-19T20:02:02.479008-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.A11ySettings.service - GNOME accessibility service.
/var/log/syslog.1:2024-11-19T20:02:02.481788-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Datetime.service - GNOME date & time service.
/var/log/syslog.1:2024-11-19T20:02:02.486048-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.ScreensaverProxy.service - GNOME FreeDesktop screensaver service.
/var/log/syslog.1:2024-11-19T20:02:02.486302-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Rfkill.service - GNOME RFKill support service.
/var/log/syslog.1:2024-11-19T20:02:02.486749-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Housekeeping.service - GNOME maintenance of expirable data service.
/var/log/syslog.1:2024-11-19T20:02:02.487078-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Sharing.service - GNOME file sharing service.
/var/log/syslog.1:2024-11-19T20:02:02.513906-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started app-gnome-org.gnome.SettingsDaemon.DiskUtilityNotify-2643.scope - Application launched by gnome-session-binary.
/var/log/syslog.1:2024-11-19T20:02:02.517976-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.A11ySettings.target - GNOME accessibility target.
/var/log/syslog.1:2024-11-19T20:02:02.518226-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Datetime.target - GNOME date & time target.
/var/log/syslog.1:2024-11-19T20:02:02.518419-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Housekeeping.target - GNOME maintenance of expirable data target.
/var/log/syslog.1:2024-11-19T20:02:02.518627-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Rfkill.target - GNOME RFKill support target.
/var/log/syslog.1:2024-11-19T20:02:02.518808-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.ScreensaverProxy.target - GNOME FreeDesktop screensaver target.
/var/log/syslog.1:2024-11-19T20:02:02.518986-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Sharing.target - GNOME file sharing target.
/var/log/syslog.1:2024-11-19T20:02:02.521626-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.PrintNotifications.service - GNOME printer notifications service.
/var/log/syslog.1:2024-11-19T20:02:02.527154-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.PrintNotifications.target - GNOME printer notifications target.
/var/log/syslog.1:2024-11-19T20:02:02.559331-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Smartcard.service - GNOME smartcard service.
/var/log/syslog.1:2024-11-19T20:02:02.560891-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Smartcard.target - GNOME smartcard target.
/var/log/syslog.1:2024-11-19T20:02:02.646553-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Sound.service - GNOME sound sample caching service.
/var/log/syslog.1:2024-11-19T20:02:02.647863-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Sound.target - GNOME sound sample caching target.
/var/log/syslog.1:2024-11-19T20:02:04.575039-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Keyboard.service - GNOME keyboard configuration service.
/var/log/syslog.1:2024-11-19T20:02:04.575563-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Keyboard.target - GNOME keyboard configuration target.
/var/log/syslog.1:2024-11-19T20:02:05.036616-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Color.service - GNOME color management service.
/var/log/syslog.1:2024-11-19T20:02:05.040604-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Color.target - GNOME color management target.
/var/log/syslog.1:2024-11-19T20:02:05.132436-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Wacom.service - GNOME Wacom tablet support service.
/var/log/syslog.1:2024-11-19T20:02:05.132724-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Wacom.target - GNOME Wacom tablet support target.
/var/log/syslog.1:2024-11-19T20:02:05.139632-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.MediaKeys.service - GNOME keyboard shortcuts service.
/var/log/syslog.1:2024-11-19T20:02:05.140840-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.MediaKeys.target - GNOME keyboard shortcuts target.
/var/log/syslog.1:2024-11-19T20:02:05.168678-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Started org.gnome.SettingsDaemon.Power.service - GNOME power management service.
/var/log/syslog.1:2024-11-19T20:02:05.168948-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 systemd[2144]: Reached target org.gnome.SettingsDaemon.Power.target - GNOME power management target.
/var/log/syslog.1:2024-11-19T20:02:05.600256-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 gsd-print-notif[1778]: Error releasing name org.gnome.SettingsDaemon.PrintNotifications: The connection is closed
/var/log/syslog.1:2024-11-19T20:02:05.602027-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 gsd-smartcard[1787]: Error releasing name org.gnome.SettingsDaemon.Smartcard: The connection is closed
/var/log/syslog.1:2024-11-19T20:02:05.607990-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 gsd-housekeepin[1845]: Error releasing name org.gnome.SettingsDaemon.Housekeeping: The connection is closed
/var/log/syslog.1:2024-11-19T20:02:05.609471-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 gsd-datetime[1798]: Error releasing name org.gnome.SettingsDaemon.Datetime: The connection is closed
/var/log/syslog.1:2024-11-19T20:02:05.610424-05:00 michaeo-ThinkPad-X1-Yoga-Gen-5 gsd-sound[1823]: Error releasing name org.gnome.SettingsDaemon.Sound: The connection is closed
grep: /var/log/syslog.2.gz: binary file matches
grep: /var/log/syslog.3.gz: binary file matches
grep: /var/log/syslog.4.gz: binary file matches
Questions
What should I do to ameliorate my situation?
References
[1] My computer runs slower now on Ubuntu
[2] Computer has slowed down A LOT!
Thomas Ward
  • 78,878
