I am having a problem with the fan speed with my new Dell Inspiron 5521 i7-3317U, Full HD with installed Ubuntu 12.04. The fan is too noisy.
After starting the Laptop, the fan starts and is not stopping or changing the revolutions at all. Still I didn't install any Windows just because the Laptop is new. What should I do: return the Laptop or will updating the BIOS will solve the Problem? I saw that there is a newer version of the BIOS: AO7.
Fabby
  • 35,017
ivots77
I suggest you to use i8kutils, a collection of utilities for Dell laptops. In this collection there is i8kmon, which is the utility I'm actually using right now.
How To solve Dell laptops fan issues in Ubuntu
  1. First of all, let's download and install i8kutils. Open your terminal and write:
sudo apt-get install i8kutils
  1. Now you've got to add i8k to your modules. Open the modules file:
sudo gedit /etc/modules
and add the string "i8k" (without quotes) to the file. Save and exit.
  1. Create an i8k.conf file
    sudo vim /etc/modprobe.d/i8k.conf
    and fill it with this code:
    options i8k force=1
Note: Some older guides will tell you to create a /modprobe.d/options file. The "options" file isn't used anymore on Ubuntu. What does matter is that you create a file with a .conf extension (the filename isn't important, but I decided to name it i8k.conf for clarity). So beware of older i8kmon configuration guides.
  1. Now restart your computer, or run this code to make i8k run:
sudo modprobe i8k force=1
  1. We will now create a i8kmon.conf file which will tell the i8kmon utility how to behave.
sudo gedit /etc/i8kmon.conf
Paste the following code in it:
    # Run as daemon, override with --daemon option
    set config(daemon)      0
# Automatic fan control, override with --auto option
set config(auto)        1
# Report status on stdout, override with --verbose option
set config(verbose) 1
# Status check timeout (seconds), override with --timeout option
set config(timeout) 20
# Temperature thresholds: {fan_speeds low_ac high_ac low_batt high_batt}
set config(0)   {{-1 0}  -1  40  -1  40}
set config(1)   {{-1 1}  30  60  30  60}
set config(2)   {{-1 2}  53  128  53  128}
# For computer with 2 fans, use a variant of this instead:
# set config(0) {{-1 0}  -1  52  -1  65}
# set config(1) {{-1 1}  41  66  55  75}
# set config(2) {{-1 1}  55  80  65  85}
# set config(3) {{-1 2}  70 128  75 128}
# end of file
This has been edited to match my Dell Inspiron 15r 5521 fan configuration (and I hope I did it well). If you want more informations take a look at the documentation on Ubuntu Manuals: http://manpages.ubuntu.com/manpages/gutsy/man1/i8kmon.1.html
  1. Now you should be able to run i8kmon from your terminal and see if (and how) it's working. Simply run:
i8kmon
Finished!
Sources:
Try to enable powersaving for chipset and other devices:
sudo apt-get install powertop
sudo powertop
Go to "tunables" tab and change all "bad" items to "good"
All changes reset after reboot. And some of them change depending on AC/Battery mode.
So you also have to make powertop changes permanent and disable pm-powersave scripts
