I use a 13.04 system. Whenever the system boots up, the Bluetooth button is by default ON..Every time i have to manually disable it.Is there any way to disable this?
To disable it on boot, you'll need to edit this file:
sudo vim /etc/bluetooth/main.conf
And set InitiallyPowered to false
InitiallyPowered = false
Disable Bluetooth on startup
Source : Is there a power saving application similar to Jupiter?
 sudo nano /etc/rc.local
And add the following line before exit 0
 rfkill block bluetooth
Save & Exit & Reboot
Your bluetooth is off on startup but you can enable it from bluetooth icon.
Qasim
  • 22,162
