17
How can I install the most used plugins like flash player and mp3 in Ubuntu?
LiveWireBT
  • 29,597
Ant's
  • 3,930
5 Answers5
18
The easiest way is to install the package ubuntu-restricted-extras by clicking the button below:
Install via the software center
This will install a bunch of useful stuff, because it is a meta-package, like Flash, MP3 capability, mscorefonts etc.
Connect to the internet. Open the software center and search for ubuntu-restricted-extras and install it.
You will have to accept some licences for non-free stuff.
First step read this from Ubuntu RestrictedFormats.
Then go to ubuntuguide. This is for Maverick - there are different guides for older versions of Ubuntu.
To install Flash search for 'Flash' in the Software Centre and install it or install the package: flashplugin-nonfree
sudo apt-get install flashplugin-nonfree
Zanna
  • 72,312
Vassilis
  • 2,957
For Flash Player, try installing flashplugin-installer and flashplugin-nonfree
For the MP3 stuff, support to listen to MP3 media files should already be loaded into the system, as was my experience with 10.04 and 10.10.
Thomas Ward
  • 78,878
If you want only free and open-source package (without enabling Multiverse) then following helps you which are available on Universe repository
For supporting MP3 most common audios & videos:-
  • gstreamer1.0-fluendo-mp3: This GStreamer 1.0 plugin permits decoding of MPEG 1 audio layer III streams.
  • gstreamer1.0-plugins-bad and gstreamer1.0-plugins-ugly : gstreamer plugins
  • gstreamer1.0-libav: This GStreamer plugin supports a large number of audio and video compression formats through the use of the libav library. The plugin contains GStreamer elements for encoding 40+ formats (MPEG, DivX, MPEG4, AC3, DV, ...), decoding elements for decoding 90+ formats (AVI, MPEG, OGG, Matroska, ASF, ...), demuxing 30+ formats and colorspace conversion.
Flash player & plugin:-
  • gnash :GNU Shockwave Flash (SWF) player
  • browser-plugin-gnash : GNU Shockwave Flash (SWF) player - Plugin for Mozilla and derivatives
Pandya
  • 37,289
On every new install of Ubuntu I always use Medibuntu in addition to the restricted extras.
Eliah Kagan
  • 119,640
Mark Rooney
  • 6,329
