I have about 20 .webm files that I would like to convert to audio in the terminal. I want to do
avconv -i *.webm -acodec libmp3lame0 -aq 4 *.mp3
I tried:
for i in *.webm; do avconv -i "${i}" -acodec libmp3lame0 -aq 4 "${i%.wemb}.mp3"; done
but it says "libmp3lame0 encoder not found." It is installed, though. I also installed ubuntu-restricted-extras and reinstalled libav-tools.
I also tried
for i in *.webm; do avconv -i "${i}" -acodec -aq 4 "${i%.wemb}.ogg"; done
to remove the whole mp3/LAME aspect, but then it just said '.ogg encoder not found.'
This worked once before when I tried to convert using libmp3lame0 without the for loop...but I just tried to convert one file and it doesn't work anymore.
Thanks. (I'm using 12.10.)
You seem to be using the wrong codec name. To see which codecs are supported, do:
avconv -codecs
according to this the codec name is libmp3lame (you have an extra 0). This is on my system however, so yours may be different. The command I gave will let you find out.
roadmr
  • 34,802
In many distros, avconv by default is not built with "--enable-libmp3lame". avconv must be compiled with MP3 support in order to utilize libmp3lame.
My working solution was to download libav from the git repo, and build it myself. This is the configure command line I used:
./configure --enable-libmp3lame --enable-nonfree --enable-gpl --enable-libx264
You can verify MP3 encoding support is or is not built into your avconv with this command line: avconv -codecs
You must see an "E" in the second column of features for MP3 encoding to work:
DEA.L. mp3 MP3 (MPEG audio layer 3) (decoders: mp3 mp3float ) (encoders: libmp3lame )
If the second column is "." MP3 encoding is not built into your avconv: "DEA.L." is good, "D.A.L" is bad.
John Drake
